Old 01-20-2005, 03:08 AM   #1
67cst
i love summertime
67cst's Avatar
damn gas all over the side of the truck? any cures?
hey guys whenever i fill the tank in the 71 i get gas on the side of the truck, do i need a new cap with a better seal or is this just normal, the paint on the truck sucks anyways so i dont care too much but oneday when i paint it id love to have that problem taken care of, any i dont want to just fill the tank half way or id be at the gas station everyday
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-20-2005, 03:09 AM   #2
67cst
i love summertime
67cst's Avatar
just to clear things up i mean like when i drive the truck after a fill up it leaks out the cap, wanted to make sure you understood that, its not like i leak gas from the nozzle when i fill the truck
Old 01-20-2005, 03:12 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I don't think it would be normal,I would get a new cap,and see if thast cures it.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-20-2005, 03:32 AM   #4
dyingdeadman
dyingdeadman's Avatar
i had that problem with a cheap cap i got from auto zone. i just put a new cap on it and it fixed that problem.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 01-20-2005, 07:36 AM   #5
I`ve had that problem,we`re not alone.I`ve seen plenty nice trucks with either dull,yellowed,or cracked paint.Or,tarnished,bleached woodgrain moulding on cab corner.After a fill-up,usually with left side sitting lower it`ll happen.Often,later on,once the temperature rises and the vapors expand.I`ve had this happen on a job-site(dirt).When I noticed,later in the morning,I moved the truck and lit the spot.Never seen a 4"diameter spot burn for so long.Probably about 10 min.Changed the cap.
Old 01-20-2005, 08:13 AM   #6
Maximum Overdrive
December 21, 2012
First thing I buy for these trucks is a locking vented cap and have never had a problem of them leaking. Only problems I have had were with stock and stock type caps.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 01-20-2005, 08:26 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Sounds like your gasket is worn. Common problem.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-20-2005, 09:01 AM   #8
1969K10
1969K10's Avatar
I had to bend the (2) prongs on a gas cap to get it to seal tight enough to quit leaking like you're talking about. And that was after replacing the gasket...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-20-2005, 09:14 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Put a blazer tank under the bed Or.....get a new cap.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-20-2005, 09:57 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
New cap should fix it. Also, when you paint, a good clear coat will resist gasoline.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-20-2005, 06:19 PM   #11
Hooter
My other Love
Hooter's Avatar
Ya happened to me, btw does anyone just make the woodgrain on its own, it's almost completley gone because of the good ole leaky gas cap
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-20-2005, 06:43 PM   #12
grayw0lf
Mine does the same thing, particularly on a hot day. I think I'm also in line for a new gasket. Ahhh, heck. I might go nuts & pay the $5.00 for a new locking gas cap.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 01-20-2005, 09:13 PM   #13
cduster
I have in the past cut a shim out of a plastic milk carton to fit behind the gasket to fix this problem.
Dan
cduster is offline   Reply With Quote
Old 01-20-2005, 09:21 PM   #14
67cst
i love summertime
67cst's Avatar
Thanks for the ideas guys, i think ill get a new cap this weekend.
67chevyredneck-i put a blazer tank under the box in my 67 and if i knew then whati know now i would of never spent money on the thing, for an extra couple hundred bucks you can a nice aluminum cell from fuelcellguy...these poly ones suck if you ask me
Old 01-21-2005, 10:01 AM   #15
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Speaking of locking gas caps, I had to use a hair dryer to get mine off yesterday! I put the old non locking cap back on until things warm up. First time that happened and it's been on there for over 7 years now. Man,it's been downright cold here in Pa! (9 degrees that morning)
The only time mine will leak gas is if I fill the tank and then park it in the sun on a hot day. The gas expands and starts dripping out of the cap.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-21-2005, 02:41 PM   #16
big blue 72
i cured my truck of the old leaking gas cap by bending the RIM of the gas filler neck up on the inside. this is what gets mashed down after time and so, the gas caps, even if new will not fit tight. TRY IT!
big blue 72 is offline   Reply With Quote
Old 01-21-2005, 03:36 PM   #17
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
That happened on mine as well. I still have the original gas cap on mine with the leather seal. I put oil on the seal and let it set and I only fill the tank to a little over 3/4. Hasn't happened since.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-21-2005, 05:35 PM   #18
shortymac83
hmm...
shortymac83's Avatar
once in a while, I won't screw it on right and it'll leak like a seive, or it'll just leak for the sake of leaking when I go around corners or something. I've just learned to fill the tank so that it won't slosh out.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 01-22-2005, 10:11 AM   #19
big blue 72
you guys need to try my cure. it really works!
