I am trying to get inside my 70 truck door to replace speakers. What is the best way to remove the door handles and window cranks without messing up the panel ect????
Resident Curmudgeon
![]() Join Date: Dec 1999
Get one of these. Most auto supply places have them. It's called a door handle removal tool.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
thanks, i couldnt remember what it looked like, or even if i could find one.
Welcome to the board from West Michigan!
A door/window handle tool works real well and they are available from most parts stores in th "Help" section. Jim |
thanks for the welcome, im clear over here in Nevada and enjoy this board.
More Cowbell....
Hey, Welcome from Central Mississippi ---You OFFICIAL Hood-Away-From-Home
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
I usually just put a hook in the end of a piece of farmers wire. Fish it in, hook the clip and "pop" it out.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
do the door handle removers come in different sizes?? the one i have isnt working and it seems to be too small???
Which way are you inserting the tool? If the clips are in the stock position, then the tool should be inserted from the roller end on the window handle and on the handle end of the door handle.
Jim |
Welcome from SW Washington State....
That's the ticket for removing the knobs. Been using one for about the last 20 years doing locksmith work on the side. And they are cheap. Somethimes those c-clips get put on backwards, so don't force it...try the other side. Save yourself some trouble when you use that tool, kind of wiggle it side to side as you work it. Those clips have a tendacy to pop off and go flying. Wiggle it and the clip release slowly and most of the time keeps the clip where it can be found.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
go cyclones
I northern hydralic has them
The eaisest way i have found is take a shop rag. like the ones that are red at the parts stores. Slide it down behind the handel and pull it toward the clip and twist it around the handle,the clip will get stuck in the rag so you dont lose it...It workes really fast if you dont have the tool. And the rag wont scratch up a good door panel...
#13 |
now question...how do you put the clips back?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
#14 |
You can put the clips on handle first,then pop in place.Good idea with the rag there.I was going to say,watch the clip flying.
#15 |
Yea the rag deal is a
