Serviceabilty of a Lowered Truck
What are the backyard mechanics useing to raise your truck for service?a modified jack?fabricated jack points?do you have pictures?i am planning on more drop and takeing all things into consideration. thanks
I have a 2 jacks. I put the small one under where the front bumper bolts to the frame to extend the suspension enough to get the big one under the crossmember. no pic, but it works for me.
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
I have 2 jacks also. 1 to get it started and the 2nd to finish the job. Sometimes it takes a little muscle to lift the front up a little so that I can slide the jack into place.
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
Not use to a lowered truck but with my camaros I use 2 short 18" 2x10"s. I just drive the front tires up on to them and go from there. gives me just enough room to get the jack under it. If you need more room you could just double them up......................jt
2011 Camaro 1SS LS3/6 Speed |
2 jacks are a must! one needs to sit real low to get under the arm!
The rearend is easy part! I also dug a 3' deep and 14' long trench that I crawl into for repairs that don't need a jack! Cheers
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Why not drive the truck up on some 2x6's?? Use 1 long one 1 shorter one then 1 short one. That will raise the truck 4 1/2". Low rider car ramps,.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
![]() Join Date: Jul 2003
I cheat, I have 4 post lift in my garage.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
#8 | |
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
I had a 4 post lift and if its to low it can be a biger deal than two jacks and wood I would have to use 2x10s to get on the rack. my buddy has a s10 with 5" and 7" drop and 17"tt2s and we just lift on one fender and the other one slides the jack in
Drive fast and Take Chances - In memory of Todd Rowe #725 Fire Chief 96 Chevy K1500 67 Chevelle 70 Chevy C10 - Old Red |
Just get a nascar stlye jack. Works fine for me.
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
#11 | |
Out draggin'
I have 2 jacks also. Using a stock 88-98 Truck scissor jack to get it up a little, then my Craftsman 3ton floor jack to finish it....
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
#13 |
trench
Be careful with the trench. No one wants to be buried alive.
Bob |
