Ebay Junky
How big is your fuel cell?
how many gallons does your truck take? For a daily driver, what is the average sized tank that you should have? also, will this tank work with a 72 its measurements are 20"wide X 18" long X 10" Deep.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
I think I have a 18Gal
Sounds like the same dim's you posted!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Ebay Junky
sorry, i forgot to mention that the tank would be going between the frame rails under my bed.
My gas tank is for a 78 Chevy van. Holds 31 gallons. Had to make my own hangers and brackets. Fuel hose connects up right in front of the rear spring hanger. Hangs kinda low, but I ain't plannin on goin off road with it. Oh yea, it fits right between the frame rails also.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Ebay Junky
do you think a 15gal. tank would be sufficient?
I think my fuel cell is a bit bigger than yours. Mine fit fine. Mine is 20 gallons and there is no way I would go smaller.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
fuel cell
You've heard "size don't matter"? well when it's a fuel tank is DOES matter! I relocated mine to the rear also. I wanted to keep enough room to install a receiver hitch. I used a tank from a chevy Luv but modified it slightly (it hung too low) well when I started driving the truck and filled it up the first time it only held about 8 1/2 gallons! I definitely will change that because 8 1/2 gal doesn't last long. I relocated the filler behind the left side marker light after removing a portion inside the bed.
Not big enough! It's around 12 gallons
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
Blazer/Burb tanks are like 20-21 Gallons and they fit perfect as the trucks and Blazer/burbs use the same rear frame dimensions. Many of our trucks were fitted with saddle tanks by dealers or aftermarket due to the fuel consumption of these gas hogs. A 20 Gallon tank is ok but a 25-30 is nicer for trips etc. All depends on what you are trying to accomplish.
Mine is 15 gallons and it tucks under the truck nicely.
