01-21-2005, 01:11 AM | #1 |
C10 Club Tennessee
Can you get a 6 inch drop using 4 inch drop springs?
If I use 2 inch blocks also can this be done. I already have 4 inch drop springs and I don't want to buy 6 inch ones.
Also Du%%a$$ question of the day, but if I get shock relocators than my stock shocks should work, correct? thanks,
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
01-21-2005, 02:02 AM | #2 |
Got L.E.D.s
Yes your stock shocks will work. but I wouldn't go lower than 4" drop springs in the rear without c-notch.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
01-21-2005, 02:06 AM | #3 |
C10 Club Tennessee
I just pm'd you bagged
01-21-2005, 09:47 AM | #4 |
Watch out for your cornhole !
You can easily go 6 inches in the rear without a notch and it will never hit unless you carry the Titanic in your bed. Every guy on this board with an ECE rear drop kit will back me up on this. I've had plenty of experience with 6 inch rear drops.
01-21-2005, 12:57 PM | #5 | |
I poop on Ford!
1972 Chevy Cheyenne - LWB, factory 402BB 2005 Chevy Suburban LT 2006 Chrysler 300C - SRT8 |
01-21-2005, 01:14 PM | #6 |
Head Peon
Don't truck and burb/blazer frames have a differnt "kick up" in the back of the frame? If I remember correctly truck frames "kick up" higher and blazer/burb frames are flatter. I know with 5" ECE springs on the back of my '72 burb it would bottom out when I hit a hard bump. Not trying to start anything, maybe hopefully just trying to shed some light on the usual "do I need a notch or not" arguement...I don't doubt on a truck you could go 6" spring and not have a problem, but on a blazer/burb it would be...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
01-21-2005, 06:29 PM | #7 |
C10 Club Tennessee
Txfirefighter, Can I get 6 inches with a 4 inch drops using 2 inch blocks?
thanks
01-21-2005, 06:51 PM | #8 |
C10 Club Tennessee
Sorry Txfirefighter- you answered my ? in another thread.
01-21-2005, 07:18 PM | #9 | |
belly dragger
01-25-2005, 03:59 PM | #10 |
F.A.S.T. president
the titanic is too long anyway, you wont get it all inside the bed
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
01-25-2005, 08:53 PM | #11 |
And I half way expected to see a photoshop of the titanic in a bed by now. I'm kinda disapointed....
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
01-25-2005, 11:19 PM | #12 |
Geoff
I have Eibach 4in coils and had a 1in block. If i had 2 peolpe in it and hit a good bump it would bottom out even w/stops removed. Maybe they are a softer spring? I now have a 2in block and c-notched and the shocks relocated and it rides sweet.
Mine for sure bottomed out but maybe the springs are stronger now. The eibachs are from about 7 years ago. Just my .02
68 SWB, 5/7 drop 406sbc. HR cam & dart iron eagles Th350 w/3000 stall H4 headlights and LED taillights |
