01-21-2005, 12:19 PM | #1 |
Head Peon
TP Watts Link Instal Article from Classic Trucks Inside!!!!
Right click and "Save Target As" then check it out:
http://www.geocities.com/sshevnock/TP/TP_Watts_01.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_02.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_03.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_04.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_05.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_06.jpg http://www.geocities.com/sshevnock/TP/TP_Watts_07.jpg I really don't like how it's welded to the diff cover and the bearings aren't sealed...and it costs $500 And congrats to N2 for making the same issue...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
01-21-2005, 12:40 PM | #2 |
I agree. It's pretty, but I sure wouldn't trust anything that's welded to the rear-end cover. I've seen them welded to the back side of a 9" housing but there's a little more metal there to weld to.
I think a better idea would be spacers that come off the housing that can attach a 3/16" or 1/4" plate for mounting the pivot link.
01-21-2005, 01:57 PM | #3 |
Mike
It is also bolted to tabs on either side of the housing.That cover is pretty strong.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
01-21-2005, 04:04 PM | #4 |
i've read this article and visited the totally polished website, but can't see shelling out 500 bucks for it. the engineering and production cost probably justifys the price, but i have done some research on the setup and am going to design and build one. i don't need a shiny pricey setup under the truck that's only gonna get grimey and pitted from the road crap. this setup is used on mazdas, mustangs, and midgets for racing and is a production setup on some other foreign cars. i found a website on design and theory of the watts link so i'm gonna give it a shot. i have access to all the machine shop tools to do it at work so as soon as i get some stock (gonna use steel) cut out i'll give it a go.
tp's website has a short video on the operation of the watts link installed in a 65 or 66 chevy truck, and it is a sweet setup.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 01-21-2005 at 07:35 PM. |
01-21-2005, 04:38 PM | #5 |
Head Peon
I heard the new Durango uses a Watts Link...haven't looked under one though to confirm it...
01-23-2005, 03:05 PM | #6 | |
However.... the system could be adapted to other vehicles relatively easy using similar methods as the TP kit, but using factory stuff (which may or may not be cheaper depending on your ability to shop around).
01-21-2005, 07:32 PM | #7 |
i agree it's an awsome option but it badly needs a redesign. i will draw up a picture of what i mean and post it later.
ondrew |
01-21-2005, 08:11 PM | #8 |
ok here's what i mean.
in the left picture is the totally polished kit. in the stock format it's really under engineered. the yellow in that picture shows whare i would add a bar to strengthen the conection between the link and the support connection. this would be added to the support bar and not the custom bracket in the right side picture. in the right side picture is a bracket that would provide the same function as welding the pivot but would let you mount it without welds or additional holes. a couple additional veiws are just below the right side picture. with these mods the link itself would likely need to be a little bit thinner but if made of steel or stainless steel it would be just as strong or stronger. just my thoughts, ondrew |
01-21-2005, 10:48 PM | #9 | |
Happy to be here
01-22-2005, 01:32 AM | #10 |
Got L.E.D.s
Are you totally sure that TP kit welds to the cover? If it is with that huge aluminum bar you wouldn't need it to be. The pressure is side to side not up and down.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
01-22-2005, 02:38 AM | #11 |
astuly here is some pressure up and down expecialy with something like leaf suspention. granted with a trailing arm setup the stress is far less but i allways say it's better safe than sorry.
ondrew |
01-22-2005, 05:36 AM | #12 |
thanks roj2323, i have been thinking along those lines also since i saw a mustang setup. the bracket similar to yours was welded to the rearend instead of bolted. i am thinking along the lines of a channel shaped bracket with mounting tabs. i wish you were closer too, we could brainstorm the hell out of this thing. as soon as i get some bearings and bolts i'll finish the design and start milling.
and yes it is welded to the diff cover bagged72blaz, the whole install is in this months custom classic trucks mag. that's the only thing i don't really like about the tp setup.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
01-22-2005, 10:00 AM | #13 |
Head Peon
The complete article is in the links at the beginning of this post...right click, save them and check it out if you haven't...
Also looks to me as if the heim joints that are on the pivot are locked and only allowed to move up and down...any agree? Also no seals for the bearings
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 Last edited by Shev; 01-22-2005 at 10:09 AM. |
01-23-2005, 02:48 AM | #14 |
Got L.E.D.s
What about one of the thick aluminum diff covers that have the cooling fins and machine it down.
01-23-2005, 04:47 AM | #15 |
i agree on the bearing issue shev. why are they using taper bearings anyway, they are primarily for thrust, as in end loading like a clutch release or wheel bearing endures while steering the front wheels in a turn, and the watts link is only gonna be radially loaded. i can only see using taper roller bearings if the rearend moved forward and backwards which it does'nt. i'm designing mine to use regular sealed ball bearings, but i may take the seals out of the inside and add a zerk ot the housing. the heims are moving up and down in the video, and only orbitally rotate a small amount.
if my thinking is going south someone please straighten me out.
01-23-2005, 07:42 AM | #16 |
I've been brain-storming with everyone here as well. I would like to see a design that uses all 10-12 bolts on the rear pumpkin. If you look at one of the S-10 locators from ***************** he has done just that. I was thinking about making a template from a cover or a gasket so it lays inside the lip on the cover. Then I would weld some gussets across vertically and horzontally to mount the bell crank to.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
01-23-2005, 11:54 AM | #17 |
What if you used a T/A performance cover? They make a 12 bolt truck aluminum cover.Check out the link. http://www.taperformance.com/gm.htm
Mark 72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction 05' GMC Sierra Denali LQ9 |
01-23-2005, 02:04 PM | #18 |
I really don't think that the link being welded to the cover is all that weak. It is being used to oppose that aluminum bracket, supporting the pivot shaft.
It is a lot stronger with support on both sides. I am rather shocked that they don't include a new cover as part of the kit though...pre-installed (Chromed, painted or even raw for powder-coating) I would agree that this is a pricey/flashy set-up that can be produced by a competant fabricator for a lot less $$$. |
01-23-2005, 03:13 PM | #19 | |
01-26-2005, 09:53 AM | #20 | |
Seņor Member
TA 1811 27 $159.95 12 Bolt Cover, Truck 12 Bolt Chevy Type Truck Differentials
01-26-2005, 04:01 PM | #21 |
Is this what every one is talking about
Is this what you guys have been trying to make or explain.......
Pictures courtesy of www.ifcustom.com Last edited by el curioso; 01-26-2005 at 04:04 PM. |
01-24-2005, 10:12 AM | #22 | |
Mike
01-24-2005, 03:50 AM | #23 |
got my pivot link cut out and welded up, almost time to start machining. i am using 1/2" x 3" bar stock (3 pieces to make pivot). gonna make a center mount like roj2323 drew up (thanks), but gonna use a piece of shallow channel 2" x 1/2". may be a while before i can test the true benefits of this setup but at least i'll already have it made. using sealed ball bearings 2"OD, 1/2"ID, 9/16"W and 3/4" threaded male rod ends with 5/8"ID. gonna get pics soon as i get all the parts cut out and mocked up which may take a while.
01-24-2005, 10:20 PM | #24 | |
ROCK ON MAN post pics when you can. ondrew |
01-26-2005, 02:53 AM | #25 |
BK Built
what do you guys think about this setup http://www.speedwaymotors.com/xq/asp...qx/product.htm i think it would work, maybe make a different or another bracket for the center to pivot on, think it would work, let me know whacha think.
