Old 01-21-2005, 02:46 PM   #1
67chevemall
67chevemall's Avatar
how to take apart rear brakes??
Yello!
I have my parts truck almost apart! I'm stuck on the rear brakes
It is a 14 bolt rear end with some big a55 drums!
Does the axcel bolts have to come off?
Is there a trick to getting these drums off???
Thanks again!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-21-2005, 03:03 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
This should help
http://www.lighthouse57.com/brakes.htm
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-21-2005, 03:09 PM   #3
60-66 Nut
Professional Beer Tester
What year truck? If it's one of the 78's you have, they don't have outboard drums like the newer trucks. You have to remove the 8 axle bolts, pull the axle out, bend open the lock tabs, remove the outer axle nut, the lock plate, the inner nut and washer, and then remove the hub/drum assembly. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-21-2005, 09:37 PM   #4
SanitysBane
wow, those are some bright brake parts...i don't know what to say....
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-21-2005, 10:20 PM   #5
magnethead
7000 #'s of american IRON
magnethead's Avatar
60-66 Nut
please tell me it's different for the D70?
magnethead is offline   Reply With Quote
Old 01-21-2005, 11:52 PM   #6
67chevemall
Peanuts!All done! For sale!
