Old 01-21-2005, 07:53 PM   #1
Primered_69
Primered_69's Avatar
BBC Crankshaft pully question
I found one today that was two piece but the front pully was broken. Is it the same as on a sbc? Or where can I get just the outer one.
(If this is a dumb question it is because I have no experience with BBC parts.)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 01-21-2005, 08:37 PM   #2
JimKshortstep4x4
Smile
The pulleys are not the same. Do you have a short water pump setup or long? Also, is your pully that you need cast or stamped?
Chevelle/Camaro BBC pullys should work for you. Ground Up Restorations is one source. BBC pulley PN ACP-844 (short water pump).
Here is a link.
Jim
http://www.ss396.com/
Old 01-21-2005, 08:45 PM   #3
Primered_69
I am not sure it came of a 71-72 suburban. I do not know how to tell the difference between cast and stamped. I would say it was whichever one is the weaker of the two. The pully cracked and broke at the bolt attachement point I guess due to overtightening.
Old 01-21-2005, 09:21 PM   #4
Bob Moore
Cast is like an engine block - stamped is like a water pump pulley
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-21-2005, 09:52 PM   #5
Primered_69
Then it is stamped. The lower pully is called the crankshaft pully right?
Old 01-22-2005, 07:55 AM   #6
JimKshortstep4x4
Smile
It is called the crank pulley. Ground Up also has the second outer pulley in a stamped version if your inner pulley is still good.
Jim
Old 01-22-2005, 08:08 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If it's just cracked, it can easily be welded.
Those pulleys are pretty hard to find nowdays. It would be worth the effort to repair it.
