Old 01-22-2005, 12:55 AM   #1
69TowRig
Need Windshield Frame - Questions
Okay guys, first noob thread for me here.
I recently bought a '69 Blazer (my first Chevy) that needs a ton of TLC.
The windshield frame is shot. Thought it would be easier to come by but apparently I was wrong.
I have started posted and PMing people looking for one.
Where do I tell a prospective seller to cut? Mine has pin holes most of the way down the pillars, so I need most if not all of it.
Anyone have any good advice on this? Anyone have one they could part with?
Thanks in advance for the help.
69TowRig is offline   Reply With Quote
Old 01-22-2005, 01:14 AM   #2
orangeuavol
GO VOLS!
orangeuavol's Avatar
contact board member slogo, he had one not to long ago.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 01-22-2005, 01:22 AM   #3
69TowRig
Thanks for the quick lead, I'll try him.
Old 01-22-2005, 08:56 PM   #4
Rod
Lets see a pic of the 69tow rig..teeitup had a windshield frame for sale too.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-23-2005, 10:47 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Where are you laocated at I have a complete cab that I am gonna cut up here soon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-23-2005, 12:11 PM   #6
69TowRig
I realized in my first post I neglected to mention that it is a Blazer (fixed first post already):
I know that makes things quite a bit harder for finding parts. I want to start doing work to this truck but I know the windshield frame is going to disintegrate the day I take the top off.
I am located in Houston, TX. No stranger to shipping my last project truck was a Nissan and finding parts all over the country for that was par for the course.
Old 01-23-2005, 01:01 PM   #7
Gee_Emm
Is it as bad as this? I don't think you have to worry about crumbling to pieces. They stay pretty strong, I tried to demolish mine with a 10lb sledge and the metal barely moved as rusty as it was.
Gee_Emm is offline   Reply With Quote
Old 01-23-2005, 01:06 PM   #8
69TowRig
Yeah it looks like that inside, but even wose at the corners. The metal has bubbled out so bad that I am afraid to take it apart. Inside the door jambs there are holes all the way down the pillars.
I guess I am trying to say that this is one part I prefer not to repair so I am looking for good parts.
Old 01-24-2005, 01:48 PM   #9
28buick
I assume you are just replacing the pillars and top frame. At the base of the pillars there are reinforcing pieces welded between the pillars and cowl. This is an excellent area to splice your new frame. If your replacement frame is cut flush with the base of the windshield you will have enough pillar material to make the splice. If you are having it shipped any distance leave the pillars connected bythe windshield base. Its a pain to cut but the frame will hold its shape. I would also suggest that prior to removing your top that you take out your windshield and make a wooden template of the opening. You will need this when you try to cut your new pillars to the correct length and weld in the new frame.
28buick is offline   Reply With Quote
Old 01-24-2005, 04:43 PM   #10
69TowRig
28Buick,
That's exactly the advice I needed. I have found someone yesterday with a solid frame that asked me "where do I cut it?" so here we go....
I started a list of sheetmetal to be repaired:
Windshield Frame
Lower right fender cup
Right Inner fender/body support
Lower Kick panels (Both)
Outer Rockers (Both)
Lower Driver's door skin (outer)
Spot behind passenger door low on tub.
I don't think that list is very long, but we shall see how long it takes to do it all!
Thanks for everyone's help!
