Turbo Guy
lowrider exhaust
I posted this in the pics area by mistake. So here goes again Does anyone have any pics of their exhaust in a lowered truck with leaf springs. Haven't got mine all the way down yet and it looks pretty tight with a five inch dump and a c notch, was wondering if I will have to cut the box floor for it. Any help is much appreciated thanks
blood type; Retumbo
I dont have any pics of my set up yet. although mine is a coil spring type this idea may work for you. about the middle of trans area have the pipes come through a reinforced hole in frame & run them along outside of frame. then snake them above the axle between the wheel & frame & straight out the back.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Here's mine, i don't rub on much, unless it's speed bump
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
Fabricate till you "puke"
Sorry, no pics on last summer's mods...... I have a 3/5 drop on my longhorn, & run full lenght Hooker comps. the old truck has 2 custom crossmembers,( 1 under the Richmond, & 1 under the rear of the cab). they are 2x6x1/4" wall, & notched for the pipes to run under. the truck runs a full lenght 2 1/2" dual system , that exits through the rear bumper(over the axle, & around the fuel cell), with 50's Flows for muffs. there is LOTS of room on a leaf spring truck to hang exhaust
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | |
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
