Old 01-22-2005, 08:53 AM   #1
68C15
blood type; Retumbo
68C15's Avatar
Red face OMG I hate to have to ask this
I normally pride myself on being an electrical guru but recent unfortunate events has led me to asking for help. on my '68 GMC 1/2 ton long wide where does the "radio" terminal of the fuse box get its supply from? I blindly attached a wire to it for feeding my electric choke & after installing a choke stat that isnt defective it up & gave out on me last night. I looked in my factory service manual at the wiring diagram & it doesnt give much details on the power supply distribution.
help please
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-22-2005, 03:18 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Todd,
Your in luck, I have the complete harness out of my 71, The radio post beside the tsc fuse (trans controlled spark) probably not used, is fused blocked (or shunted) on the back into the following fuses, ac, heater, b/u lamps, wipers, and flasher beside those fuses. They receive there feed from the brown&brown/white wire wire off the ignition switch acc terminal. Hope that helps......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
