Old 01-22-2005, 10:20 AM   #1
nevada70chev
Brake Fluid ???'s
i am going to do all new drum brakes. drums, shoes, wheel cylinders, springs/hardware, wheel bearings. did i miss anything? my question, how do i clean out all the old brake fluid? is there a simple/smart way to do it? this will be for the fronts and rear. thanks - any other advice is welcome.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 01-22-2005, 11:05 AM   #2
powell72
powell72's Avatar
Suck out the fluid with an old turkey baster, wipe out the crap at the bottom and refill before you start bleeding. You can use some brake clean to help clean out the master, but don't use very much. I have made my fair share of older master cylinders go bad from using too much brake clean. The old seals don't seem to like the stuff.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-22-2005, 01:57 PM   #3
Don R. Dodson
You can flush out the system with alcohol.
~ Don ~
Don R. Dodson is offline   Reply With Quote
Old 01-22-2005, 06:35 PM   #4
rage'nrat638
rage'nrat638's Avatar
if your changing all the wheel cyl's by the time you bleed every thing....you will have changed all the fluid....
buy a mighty vac. brake bleeder ....best tool i bought for doing brake's by my self....
rage'nrat638 is offline   Reply With Quote
