Old 01-22-2005, 04:49 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
how to get printed circuit off without damaging it?
when i try to take the nuts off the printed circuit it grabs the circuit and twists it around. what am i doing wrong?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 01-22-2005, 05:54 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'll get a better amount of responses if you post technical questions on the question board rather than the parts board.
Old 01-22-2005, 05:58 PM   #3
67ChevyC10Stepside
i wasnt sure where to post this. i figured people tearing parts apart would know.
Old 01-22-2005, 07:10 PM   #4
lamar
lamar's Avatar
use the same size wrench and hold the bottom nut while turning the top.
72 C-10
lamar is offline   Reply With Quote
Old 01-22-2005, 07:36 PM   #5
67ChevyC10Stepside
i dont see a bottom nut on the fuel guage...the other one has a real real thick nut under each stud.
Old 01-22-2005, 10:15 PM   #6
lamar
lamar's Avatar
The real thick one is on the temp gauge. All of the other gauges have a the same size nut on top and bottom. Well if someone didn't take it apart already, they all should have 2.
72 C-10
