AUSTIN TX
Question about removing the heads
Ok, how can i start this, I have been trying to remove both heads from the motor for the past 2 hours, i loosen up the 8 bolts inside and the 8 bolts outside, and I tried to remove the heads but it just wont budge, is there something that im missing, i left the rockers and rods in place, do I have to remove them two before removing the heads. by the way i have a 87 chevy sctotsdale with a 305 engine. please help. thanks
If you have all the bolts out they just need pryed loose. It will take some thing healthy like a tire iron large pry bar..
if you have all the bolts out...they should come off.....
use a pry bar.....in the front and pry up.....they might be stuck real good.... you do have the exhaust manifolds off correct? mark |
I pretty sure it's 9 under the valve cover and 8 along the exhaust manifold.
I always pull the rods so they don't get bent when I pull the heads. It will also make it easier to put back in.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne Last edited by dwaite72lnghrn; 01-22-2005 at 08:24 PM. Reason: adds |
AUSTIN TX
yes the manifolds are off, but i only counted 8 inside the valve cover and 8 outside.
there are 17 bolts for each head so you missed one somewhere
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
AUSTIN TX
ok then i missed one from the inside, it has to be somewhere inside. I will continue to look thanks very much.
Did someone say MUD?
Heck ive even used a small flat head screwdriver to pop them up and break the seal. Good luck man...Later Mike
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
Project92 SWB stepside
Ive been there!!! Prying and prying and OH $hit that why its not coming off.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
