01-22-2005, 11:06 PM | #1 |
Need To Find..... Who Knows Where......?
Need to find weld-on axle/spring perches for a 14 Bolt 10.5" Full floater that are long enough to accept U bolts running through them. Using the stock 3/4 ton U bolts.
Anybody know who sells these?? Thanks, 72longbed |
01-23-2005, 11:10 PM | #2 |
Check with your local 4 wheel drive shop. I had to replace some on a dana 60. They cost about $20.00 Woody
01-24-2005, 07:49 AM | #3 |
Rear end saddles
I assume you are putting the rear under a coil spring truck? If so I put a FF 14 bolt under a 68 coil spring truck. I was able to find the weld on sadles at a local Nascar team. They use them to put 9" under winston cup cars. They even had the correct angle to bolt right up to the trailing arms! Pretty sweet deal! They were cheap to, I think I gave $20 for both. Anybody who supplies to Nascar should be able to get them. Try BSR Products. They are a HUGE Nascar parts supplier here. Hope this helps.
BBB Last edited by BigBlockBurris; 01-24-2005 at 12:44 PM. |
01-24-2005, 11:42 AM | #4 |
BBB,
could you check for me where you got those please? I like the fact that they were already cut for the proper angle of the trailing arms. Your price is much better than BSR also. Let me know if you can track down where you got them and what you paid please. Thanks, 72longbed |
01-24-2005, 12:46 PM | #5 |
Saddles
72longbed,
Unfortuantely, BSR is going to be your best bet. I had a friend that had a friend that worked at Curb Motorsports. Thats where mine came from. Unfortunatley he no longer works there so If I was needing a pair I would have to go to BSR. I am sure that is where they came from. They may be $$$ but they are a true "weld" on. Very nice pieces. Hope this helps. BBB |
01-24-2005, 12:56 PM | #6 |
Bbb .. Could You Please Post A Pho. # Or A Web Address For Bsr? Thanks John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-24-2005, 07:53 PM | #7 |
BSR Phone #
BSR Products
1-704-795-0901 This is the number for the one in Concord NC. there is also one in Mooresville NC. Hope this helps. BBB |
01-24-2005, 08:05 PM | #8 |
Look in the yellow pages for spring/truck frame shops. There is on here that makes springs and so on.
01-24-2005, 08:25 PM | #9 |
user # 2756
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-24-2005, 08:46 PM | #10 |
Thanks everybody, I'll order a pair tomorrow.
New Question: What is the correct width of a front Dana 44 for a 72 K20?? Measured from WMS to WMS?? Thanks, 72longbed |
01-24-2005, 09:18 PM | #11 |
Chevy Freak
front axle
Good news Phil, I found 2 complete front axles in the garage. I'll grab the flashlight tomorrow and check to see what exactly they are. I know the one came out of a 71. I can't remember what the other is (it may be the 79). Brian
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
01-24-2005, 09:26 PM | #12 |
Brian,
thats great news! Thanks for looking in this frrrrrrrrrreeeeeeezzzzzzing weather we're having! Just wanted to remind you, I need 8 lug axles. Talk with you soon, 72longbed |
01-24-2005, 10:15 PM | #13 |
Chevy Freak
axles
They're both 8 lug. I'm such a parts whore. I think I might have even been planning on using the 71 until I bought the local one with all new rotors, etc. I must have forgotten about it. I haven't ventured into the rearend pile in the garage for a while. What a mess..............
01-24-2005, 11:32 PM | #14 |
Brian,
sent you a PM. 72longbed |
