Old 05-27-2002, 11:32 AM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Purrs...heater core
From old board;
Anybody have instructions on how to remove all that heater box stuff? I'm afraid to just start unbolting everything. I noticed my floor mat was wet on that side, I'm assuming it's my heater core.
You have A/C, or non A/C ?
If you don't have factory A/C, you just pull the outer box and the heater core will be right there.
Make sure it is coolant on your carpet, and not rain water, my coolant leaks to the outside, and rain water leaks to the inside.
If you have an A/C truck, I am of no help to you.
Old 05-27-2002, 12:17 PM   #2
Purs
Got Big Block?
Purs's Avatar
Longhorn, Thanks. I should've known to put that it is A/C. and yes, it's that sweet smelling coolant. It is my heater core right?
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 05-27-2002, 12:19 PM   #3
Longhorn Man
Could be a hose or a loose clamp, but my money is on the core.
Old 05-28-2002, 08:43 AM   #4
Low69CST
You need to start from heater vents ( the end right over the transmission hump) and work your way toward the box bolted against the firewall. Located on the back of your diverter box is a compressor swithc, unplug that, then, once all those vents are removed, unplug the heater resistor (inside the box) and relay bolted to the passenger exterior of the box. Once that is done, pull the hoses from the heater core ends under the hood. then there are four studs sticking through the firewall into the engine compartment. Spin off those 4 nuts and it the box should come out. Then just take out 4 small screws holding the heater core in that box. I just put a new one in my truck and I can tell you the replacements are not dimentioned right. I had a friend get me one and the tanks were too big. So the steel strap that went around them that held the core in the box was stretched out and wouldn't let the holes line up. He got me another one, had the same problem, but I was able to get it bolted up.
Also i learned that when you buy a replacement heater core you have several options of varying price. Well, he got me 2 different ones. One was a cheaper brand, 35 bucks the other was the top of the line 85 bucks. Well, after I had trouble with the first one we put them side by side and the cheap core and the expensive core were exactly the same. They even had the same stickers in the same location. So beware.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-28-2002, 09:09 AM   #5
Purs
Got Big Block?
Purs's Avatar
Thanks Low69CST!
