Old 01-23-2005, 09:00 AM   #1
wxman1
To Cut or Not to Cut
I've got a new Painless wining harness for my 69 C10 pickup.
When I got this truck about 2 1/2 yrs ago, I installed a custom dash.
I've machined a new aluminum plate dash and I'm getting it fixed up
to replaced the wooden one.
When I originally put in the custom wooden dash in I cut the old (original)
dash harness connector off. Well, I'd like to NOT do that to the new
Painless harness (pictured below). Anybody got any suggestions?
Jim
Mt Juliet
655 am with 15F - a skiff of snow on the ground
wxman1 is offline   Reply With Quote
Old 01-23-2005, 09:02 AM   #2
wxman1
Sorry...here's the picture.
file:/home/jmoser/p1230081.jpg
Old 01-23-2005, 09:05 AM   #3
wxman1
OK...one more time
Old 01-23-2005, 12:21 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Get the other half of that connector and wire to it.Then you can use the harness the way it is and the other plug will be wired into your dash. Then you can just plug them together
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-23-2005, 12:40 PM   #5
wxman1
Connector??
As far as I know...this connector fit into a "connector slot" in the original
dash (shown below). Is there a matching female connector out there
somewhere??
Jim
Mt Juliet
24F...but the sun it out!
Old 01-23-2005, 03:02 PM   #6
bad69
Struggling Artist
Painless Wiring makes a complete guage harness for the aftermarket guages, you do have to replace the original connector, but Painless makes it easy to do.I put it on my 69 and it looks clean.
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
Old 01-24-2005, 12:45 AM   #7
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Well you could try to contact painless and see if they will sell you the pins for that connector. If they will, remove the pins cut the wire right behind the pin and go for it. If you ever want to go back stock, cut the old harness back off, re-install the pins and you are in like Flynn.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
