14 Bolt for the Off Roader...SHAVED!!!!
Well finished a new project/ product. We will be adding this to our site this year. Not sure of a price yet, but do know the customer will supply the empty housing. Or it will cost a little more if we supply it..
No more 14 bolt hanging lower that you dana 44 or dana 60 up front. We have shaved about 2- 2 1/2" off the bottom( great for the rock climber that wants a strong axle but didn't like the low point of the diff) We have also added a stronger Diff cover to it also. So no more worries about bashing a rock and ripping your diff cover. This is better than a Rock ring. What do you guys think?
Support The Board |
Like it.How much meat is left in housing?What`s the cover made from?
Land Beast
heres a step by step article for this mod scrool to the bottom of the page. http://www.pirate4x4.com/tech/billav...ble/index.html
90' GMC 1 Ton Suburban |
The cover is a 3/8" ring around
3/8" in the center over the ring gear. 1/4" plates on the sides of the center. Ours is a 1/2" plate machined for 40 thousands for ring clearance on the bottom. we remove about 2" off the bottom. You gain about 1 1/2" ground clearance. Ours is also Welded by a certified cast welder.
Support The Board |
Killin' Time
so, how does it seal on the bottom where there is no flange for the gasket?
NEED CORVETTE 1972 GMC C20 350, SM465, HEI Dynomax headers and 2.5" duals |
I'd like to be the first to test it out for you, when can you install? LOL
Great looking job! ![]() |
Did someone say MUD?
I like it man, good job on it guys...Later Mike
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
#8 | |
Thanks guys This isn't really the novice type job to try.
Support The Board |
