My front suspension cross member has a couple welds on the inside of the lower control arm mounts I was wondering if they were factory or not. I was hoping u guys with the two wheels drives could help me out on this. Cause I am thinking they are not factory.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Spot welds? If so, they are factory and they hold the top and bottom portion together.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
They are definitely not spot welds they are about a inch wide. They run from top to bottom on the crossmember. If this helpsone of my motor mount plates was weld to it.
1945 Chevy 1/2 Ton 1953 Suburban 1955 SWB Big Window 2 1959 Chevy Fleetside 1966 Chevy 1/2 Ton 1975 1/2 Ton 1984 1/2 4X4 |
Where on this picture, top or bottom. I don't see how your motor mount was welded to something on the bottom where the lower control arm mount is when it bolts to the top, so I am a little confused.
![]() Are you saying the weld runs up the front (in pic) of the crossmemeber? If it is a bead, and it is on top, it ain't fatory. It sounds like the either has a different motor in there and welded motor mount on, or they broke a bolt and instead of fixing it, they welded it.
looks like someone had some fun with that one! id probably get another one, any year one will work, 60's-up
Well, I don't know about his, but I had fun with mine.... <GRIN>
I think some one had some fun with it. Or was to lazy to replace it after it got cracked. Cause where the triangles are is where the welds are they run from the bottom of the crossmember to the top where the motor mount plates are.
1945 Chevy 1/2 Ton 1953 Suburban 1955 SWB Big Window 2 1959 Chevy Fleetside 1966 Chevy 1/2 Ton 1975 1/2 Ton 1984 1/2 4X4 Last edited by King_Cobra; 05-28-2002 at 06:35 PM. |
