Old 01-23-2005, 07:30 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Favorite modification?
What is your favorite modification you have done to your truck?
Not just looking for the high end stuff here...HEI may be my favorite...but since I have never had to mess with points, I really don't know what I missed out on.
Even though I've only put 10.5 miles on the longhorn so far, I am lovin that caddy torque...I'm thinkin that is my top mod.
Lets hear what you have.
Old 01-23-2005, 07:33 PM   #2
shortymac83
hmm...
shortymac83's Avatar
well, probably the best mod that I"m planning with my truck is swapping in a 292 with a 4bbl, headers and 9.5:1 compression. Either that, or highway gears, so I can actually keep up with traffic.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 01-23-2005, 07:34 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Definitely HEI swap for me.
I've never bought a set of points for my vehicles. I refuse to spend money on the things. By the time any of my vehicles need a new set of points/ condensor, I'll swap to HEI.
Old 01-23-2005, 07:36 PM   #4
Longhorn Man
Yeah, the furthest I've ever gotten with points is from the seller's house to my house...and both times was with a chain, so in all reality, i have NEVER driven on them.
Old 01-23-2005, 07:43 PM   #5
71gmcfanatic
This is my favorite mod, brand new gm 350 crate. Nothing special but it is stone cold reliable.
1971 gmc 3/4 ton, 350, t350
71gmcfanatic is offline   Reply With Quote
Old 01-23-2005, 07:40 PM   #6
Tx Firefighter
My father in law laughed at me awhile back because I gave him a Mallory Dual Point distributor for SBC.
What he thought was funny was when I told him "The only thing worse than a set of points in a distributor is two sets of points in the same distributor". He got a real kick out of that. He also got a free distributor.
Old 01-23-2005, 07:51 PM   #7
ebfabman
Blazer tank install, 67 chevy style body on my 72 (no marker lamps or trim)
ebfabman is offline   Reply With Quote
Old 01-23-2005, 08:00 PM   #8
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
either the crate engine or the mp3 player
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-23-2005, 08:03 PM   #9
Mudder
Post Whore
Mudder's Avatar
gas tank (31 gallon) Blazer tank/ 4wheel disks/ autometer guages
Mudder is offline   Reply With Quote
Old 01-23-2005, 08:04 PM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
Good question Andy...I'd have to say suspension.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 01-23-2005, 08:14 PM   #11
BowTie Billy
Points Well Taken
I lived with points in my 62 Impala and my 70 Z28-HEI lets you drive without the constant tinkering-Never really thought about it but great question.
BowTie Billy is offline   Reply With Quote
Old 01-23-2005, 08:33 PM   #12
SCOTI
SCOTI's Avatar
After driving my 6cyl 67 for several years, it wasn't reliable or secure in wet weather. Fast forward several years (in time & mechanical experience) to when I purchased my 68, one of the first swaps I did was factory disc brakes & HEI.
Night & day difference! The discs are much more consistent & the HEI has never given me even a hint of trouble. I wish I would have done both mods to my 67 back then. Second to those changes is HD gas shocks & a front sway bar w/poly bushings.
Next on the list for the 68..... V8 + auto OD swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2005, 08:26 PM   #13
Sweet72
Sweet72's Avatar
For me it was power brakes with a disc/drum setup one heck of a difference! Power steering is a close second, unless you have 16" biceps.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-23-2005, 08:27 PM   #14
Exille
The removal and overhauling of my original 350 w/ 450k+ miles
Exille is offline   Reply With Quote
Old 01-23-2005, 08:33 PM   #15
me3
hart
Ill just be happy to get her done this year.
me3 is offline   Reply With Quote
Old 01-23-2005, 08:40 PM   #16
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I took the points,and junky 2 bbl off and swapped on an aluminum intake (factory jobber) and a qjet,and an HEI some 8 mm wires.Made a world of difference in performance.That and the tilt column.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-23-2005, 10:06 PM   #17
roj2323
so far this is my favorite modification:
shaving the extra steel around the crossmember not only makes it look cleaner but it also doesn't hold water anymore. now i'm sure i'll have even better mods in the future but that's what i got so far.
ondrew
humm i wonder if the 355 one peice rear seal engine counts?
roj2323 is offline   Reply With Quote
Old 01-23-2005, 10:13 PM   #18
1969 GMC
1969 GMC's Avatar
Hm, I didn't have to do a lot to my truck while it was my DD, but my favorite aesthetic mod would definitely be ditching the 3 original cracked and faded hockey puck marker light lenses for some of the newer style (2 of the originals were already gone and replaced when I got the truck). I also got to see what color my truck was when it was brand new, due to the perfect paint under the marker light's rubber pads.
Ditching the crappy AM/FM/8 track that was in the truck and putting a radio delete in the hole cleaned the dash up alot. Then adding my Pioneer CD player in the GB gave me some awesome tunes, so its up there too.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-23-2005, 10:26 PM   #19
Huck
Huck's Avatar
Favorite Modification
Andy, favorite is a interesting category---HEI for reliability, positraction for traction, sway bar for handeling, 8" ralley wheels for handeling, new crate 350 for reliability, Original AM/FM for looks, Buckets & console for convenience, Headers-edelbrock carb==for performance---the el-cheapo aftermarket windshield washer pump mounted under the hood, or maybe the blue halogen headlights from Ricks'. The 5 speed is cool but for the cost---a 700R4 might have been a better solution.
Huck is offline   Reply With Quote
Old 01-23-2005, 10:39 PM   #20
tnblazerk5
User #12137
tnblazerk5's Avatar
lets see ,,,,, built 327 ,hei dizzy , headers , turbo 350 trans , power brakes , front disk brakes ,crager ss mags(they are used but better than nothing) ,yet to be instaled, front and rear sway bars , 71 bucket seats and console , tilt , wood grain glove box door and ash tray and gauge dash (lookin for woodgrain 70-71 door panels) ,theres more but cant think of them rite now and just draging the truck out of retirement last year (it sat for 10 years in my driveway,didnt touch it)so everything i have did in the last year has got to be the best ones
tnblazerk5 is offline   Reply With Quote
Old 01-24-2005, 12:31 PM   #21
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I did an inventory last night and realized that the only original items left on my truck since CARS4567 left it in my pasture are the frame, two rear fenders and the grill! I think almost everything I have done has been an improvement...but my favorite has to be the rear bags...love the drop!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-24-2005, 04:45 PM   #22
724wdcopper
graphic designer
724wdcopper's Avatar
i'll go with '95 350, hella headlight conversion with 100/50 bulbs, PIAA driving lights (100watts each), self dimming rearview mirror, third brake light/cargo lamp combo, 18" Enkei's. used to like my stereo until it grew legs and wandered off '62 Pontiac tach on the column (even though it doesnt work yet)
724wdcopper is offline   Reply With Quote
Old 01-23-2005, 10:17 PM   #23
lukecp
Formerly yellow72custom
lukecp's Avatar
Any one of these:
1. Flowmaster exhaust and headers
2. 200 watt Sony CD player (in my Saturn now though...)
3. Edelbrock 1406 carb
4. Modified gauge cluster with a tach and aftermarket oil/water/volt gauges.
5. Ditching whimpy skinny 235/75-15 tires for beefier 255/60-15's
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-23-2005, 10:26 PM   #24
Eddie H.
Eddie H.'s Avatar
For me It would have to be swapping the original anemic 307 for a mildly built small block 400. Power steering and power brakes would come in as a close second and third as far as making the old girl much more driveable.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-24-2005, 11:18 AM   #25
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
1 ) Late model steering Wheel
2 ) Late model 60/40 seat
3 ) HEI
4 ) Edelbrock carb
5 ) Dead soft Header gaskets
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
