Old 01-23-2005, 07:45 PM   #1
jamie72
jamie72's Avatar
dash lights won`t come on.
i just bougt an 85 c-10 and i don`t have any dash lights, i checked the fuses,any suggetions??
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 01-23-2005, 08:15 PM   #2
hotrodhomi
hotrodhomi's Avatar
did you check the dimmer?
hotrodhomi is offline   Reply With Quote
Old 01-23-2005, 08:25 PM   #3
magnethead
7000 #'s of american IRON
magnethead's Avatar
dimmer or something in the wiring. whip out your multi-meter.
magnethead is offline   Reply With Quote
Old 01-23-2005, 10:13 PM   #4
weekender
Had the same problem, pulled out an replaced light switch, problem solved.
weekender is offline   Reply With Quote
Old 02-06-2005, 08:37 PM   #5
turbo 6.2
if the fuel gage quites workin to when you turn the head lights on. ihad this problem it is in the gage cluster and u will have to find a different cluster to put in.
turbo 6.2 is offline   Reply With Quote
Old 02-07-2005, 02:18 AM   #6
Russell
Professional Grade
Russell's Avatar
If the fuel gauge quits working when you turn your headlights on (and your signal lights in the dash come on, along with the high beam indicator being reversed) then your ground is bad. Check the ground at attaches to the bolt on the emergency brake.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
