01-23-2005, 10:49 PM | #1 |
front end swap?
Ive done a search and talked to a few guys who have done the newer cross member swap and Im confused. Ive been told that a cross member all the way up to an 87'will pretty much bolt right in. But Ive read on here or classis chevy board that around 80' the crossmember changes to metric (or somthing, what does that mean? Ive got a 64' with no motor or tranny....so Im thinking if I can find a 70's or 80's 2wd for like $500 that is complete I could get the front end and a motor to build all in one to make life easier. Also arent vans on a truck chassis cause if I could find a van I could probly get a gas tank too.
Any help appreciated.... |
01-23-2005, 11:30 PM | #2 |
Captain Ed
I bolted a 72 front crossmember in my 66, Bolted right up. Don't know about the metric issue with the later trucks though.
01-24-2005, 10:32 PM | #3 |
the crossmember doesn't change,the power steering pump does.just use the steering box and pump off the same truck.i have 1980 crossmember and steering with a 73 box and pump.buy a truck up to 87 and transfer it all over.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
