Old 01-24-2005, 01:30 AM   #1
flat57
Question tranny bolt patterns
I assume that the 235 inline 6 has a different transmission bolt pattern from the later 265,327,350 small block V8s. Is that correct?
If I wanted to hook something like a 200-4R or 700R4 behind my 235, does anyone know if there is a good way of doing it (adapter plate, flex plate, etc.)?
1957 3800 flatbead
flat57 is offline   Reply With Quote
Old 01-25-2005, 10:12 PM   #2
me3
hart
Im 99% sure that all chevys are the same up till 95ish. my 85 had a v6 to start with then a 327 then a 350 now im going back to simple 235.
me3 is offline   Reply With Quote
Old 01-25-2005, 10:26 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Negative. The 235 was a different pattern than the common GM pattern. The common pattern started in the ealry 60's on six cylinders with the 230 engine. The small block had the common pattern since it's introduction in 1955.
Check out www.stovebolt.com and look at the forum board. That board revolves around 235 engines.
Old 01-26-2005, 01:36 AM   #4
flat57
Yup. Stovebolt had the info. Looks like there are adapter plates, but I wonder if the old 235 is actually capable of pulling the truck in overdrive at 70-80 mph.
1957 3800 flatbead
