Old 01-24-2005, 03:12 AM   #1
kevinr1970
A little help please (II)
After swapping the engine in my Blazer, I am left with some things that don't go anywhere. I don't think they went anywhere to begin with, but am not sure. Can anyone tell me what these things are for and if I need to hook them to something???
1st and 2nd pictures are of a three prong plug (edge is burned away so you don't really see the third slot)/receptacle. I'm pretty sure it wasn't hooked up when I bought the truck and someone said they thought it was for a 700r4 which the truck no longer has (T350).
In the second picture there is another plug (above and to the left of receptacle plug) that I also don't think was hooked up to begin with?
3rd pict is a plug with four fittings(?) and it has a lot of green on it. I'm not sure if it was hooked up or not?
4th pict is a plug above the distributor cap that is the same situation as above.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-24-2005, 10:36 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The third one looks like it might be for an ESC distributor? I can't remember if mine had the weather pack connector, or whatever it is called.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-24-2005, 12:12 PM   #3
kevinr1970
The truck does have a ESC badge on the back, but I think that stuff is long gone. So I guess I don't need to worry about that one?
2000 Tahoe Limited
Old 01-24-2005, 12:32 PM   #4
Ric83
Ric83's Avatar
Yup, that is the plug for the ECS on the dizzy. If it does not have it anymore, no worries then.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 01-24-2005, 05:58 PM   #5
SanitysBane
4th looks like the plug for the a/c
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-24-2005, 07:06 PM   #6
Destructo
that explains the extra plugs for my 85! I think I had ESC (not anymore) the a/c plug is just hanging there, and the plug for the oil pressure sending unit (mechanical gauge).
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
