Señor Member
Xmember install progress
I drove my truck up to slammed67's place this weekend for the xmember swap. Here's progress...
Señor Member
and then after the
67-72 parts collector,…
![]() Join Date: Nov 2002
XXL,... What are you going to do with the old crossmember? I'm looking for one to cut up.
#4 | |
Señor Member
PM'd you,...
Project92 SWB stepside
R U done yet??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Señor Member
Nice road rash I've got on the front edge of that control arm. Note: Somewhere in Wichita there's a missing yellow dot from the road.
Señor Member
slammed67 is such a diligent worker. Here's a progress pic...
Señor Member
more...
Señor Member
BTW... capt kaos, we discussed potential tie rod clearance issues, but you felt it wouldn't be a problem. Oops
belly dragger
I hear grinding noises in your future. I"ve had to do that to every crossmember I've built so far same spot.
#12 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#13 |
XXL, CaptKaos, or Slammed, how much of notch is that crossmember?
#14 |
Progress = 0%
1.5"
#15 | |
Señor Member
#16 |
How come there is not alot of Pabst Blue Ribbon. I see ALOT of Lite's though. Pabst Blue Ribbon is the poor boy special!
#17 |
OUCH I remember asking those questions to Bill Turner when I was only going to do the member and not the Rack and pinion. He spoke of turning the parts backwards somehow?? Not sure if he was blowing $hit up my ARSE or what??
#18 | |
Señor Member
#19 |
Slammed, you have PM.
#20 |
Señor Member
Almost done...
#21 |
Señor Member
Let the problems begin...
#22 |
Where are your spacers for the upper control arms? You also need your borgenson joints to clear your upper arm, any time you go that low you are going to need to do it.
Where are the budweisers? |
#23 | |
Progress = 0%
#24 |
Trucker.
On my buddies 85 the shop that did the alignment used spacers that were dished to match the shaft on the outside of the spacer stack.
#25 |
Progress = 0%
Did '73+ trucks have such a spacer on them from the factory?? That's the only explanation I could come up with.
