Old 01-24-2005, 03:16 PM   #1
PHOENIX
What is this? See picture
I had to change the heater core this weekend and decided to remove this thing (on top). I left the one on the bottom there for now.
What are they?
I think they are related to the after market A/C system that was in this truck. I removed most of it as I come across it.
If anyone knows what these are please reply
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-25-2005, 01:02 PM   #2
PHOENIX
OK so nobody knows what these are
Can anyone confirm that these are not factory components?
Old 01-25-2005, 03:31 PM   #3
60-66 Nut
Professional Beer Tester
I can't even look at the picture to give you an idea. All I get is a red X, when I click on it nothing happens. Or maybe even less than nothing. Is it something with my browser settings?
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-25-2005, 03:43 PM   #4
ocbaud
Garage Queen Material
i've never seen that in my truck or any truck i've worked on stock
ocbaud is offline   Reply With Quote
Old 01-25-2005, 03:48 PM   #5
Prerunner1982
Prerunner1982's Avatar
60-66nut, it maybe your browser, i have viewed this thread a few times with no problem, to see it, right click over the pic, then go to properties, then where it says location...highlight the url (web address). Open another browser... past url into browser it should show up then..
Eddie, i have something similar on my firewall, but i believe it is the torque converter lock up. but it only has one vac. line, not 2.. disconnect it and see if anything happens. safe to say its useless... or you could disconnect the plug and hook a multimeter up to it and play with your A/C controls and see if something happens..
Prerunner1982 is offline   Reply With Quote
Old 01-25-2005, 03:50 PM   #6
Jonboy
Slots go on anything!
I have never seen them either, for what is's worth. I would bet it is to your aftermarket a/c.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-25-2005, 05:49 PM   #7
PHOENIX
I removed it saturday and been driving the truck since.
Probably for the after market a/c system.
BTW that wire at the top on teh first picture is a ground to the firewall.
The vacuum line from the top actually hooked to the bottom part.
The bottom part controls the flap near the blower.
The other vacuum port on that top thing must have hooked up to the engine somewhere to get the vacuum.
Old 01-25-2005, 09:45 PM   #8
ureckme
ureckmefixit2@cox.net
Its an electric vacume switch. A/C to close heater vent when A/c running. Matt
ureckme is offline   Reply With Quote
Old 01-25-2005, 11:05 PM   #9
smokinn
smokinn's Avatar
Its a blue arrow used to point at things.
smokinn is offline   Reply With Quote
