Old 01-24-2005, 03:49 PM   #1
BigSky71
LAIDOUT
BigSky71's Avatar
71 Drivetrain, 68 frame; any issues?
I plan on building my truck using a '68 SWB frame I got nearly free, using the drivetrain of my '71 Cheyenne LWB [both trucks are 2WD]. Before I prep the '68 frame I thought I better ask you guys if the front and rear suspensions mounting points are the same, and also will mounting the '71 front clip on the '68 frame be a problem?
I got the '68 frame a few years ago, and have always assumed the frames were the same [except the wheelbase], but I thought I should check first.
Thanks!
BigSky71 is offline   Reply With Quote
Old 01-24-2005, 03:54 PM   #2
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi. You shouldn't have any issues with the frame. You may want to swap the disc brakes and 5 lug rear from your 71 to your 68 first of all. Good luck and post pics of it in progress.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-24-2005, 04:13 PM   #3
BigSky71
LAIDOUT
BigSky71's Avatar
5 lugs and the disks definitely, the only part of the '68 that I intend to use is the frame. I will use the 71 front and rear suspensions, well except the springs, it will be all air ride.
I will post pictures of all the significant milestones for sure.
BigSky71
Old 01-24-2005, 10:33 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have a 69 with 72 suspension front and rear worked out really well.... Welcome to the board..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
