Old 01-24-2005, 11:57 PM   #1
duke68ss
Leaf Spring to Coil Overs? Can it B done?
The title says it all.. I have a leaf spring set up and wanted to convert all my rear end suspension to coil overs. Can it be done and how hard is it? Thanks everyone!!
duke68ss is offline   Reply With Quote
Old 01-27-2005, 07:18 PM   #2
2low72
I'd like to know too..
TTT for ya!!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 01-27-2005, 09:15 PM   #3
roj2323
from what i have read on the various other threads in the past week............. yes
you will have to make brackets to hold the coil springs but otherwise it should be fairly easy all be it time consuming.
ondrew
roj2323 is offline   Reply With Quote
Old 01-27-2005, 09:43 PM   #4
RON WOODGEARD
Resident Young Old Dude !
Yes,
It's not hard as long as you have the tools, or have a friend that does. You will need to find Trailing arms, The brackets that go on the Crossmember that the Trailing arms mount in, Then you will need the Panhard bar. Truck height will depend whether you use the stock one or have to buy a Adjustable one.., Coil mounting pads from a donor, and the "U" bolts that hold the trailing arms to the rear end housing..You will have to do some fabrication on the rear end housing..
I Forgot you'll need springs also !!!!
You can buy all of this stuff new, Or find a Donor in a wrecking yard with Good condition "non rusty" parts..
This is a changeover I will also be doing sometime in the future.. How far in the future is the question......
This is a great changeover, The trailing arm suspension is the same thing Nascar vehicles use, and the ride is smoother..
RON WOODGEARD is offline   Reply With Quote
Old 01-27-2005, 09:54 PM   #5
racer face
duke68ss,
why do you want to go to coils, if you plan on doing any hauling leafsprings will haul
more weight. if weight isn't the issue, and say traction is. I wouldn't waste the time
putting in stock coils, I'd go for a four link and coil over shocks it's alittle more involved
and cost alittle more but,well worth it. If you do stock stuff it isn't to hard alittle time
consuming just make sure you have a good donor to get all brackets, drag links, spring
purchases, and mounts from.as well as a cuting torch and a welder.
racer face is offline   Reply With Quote
Old 01-27-2005, 10:48 PM   #6
Liftedassdodge
The Stunt Guy
didnt the chevys come with a 2 link and coilovers?
Liftedassdodge is offline   Reply With Quote
Old 01-27-2005, 11:35 PM   #7
72MARIO
72MARIO's Avatar
Nope. It was a option.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-27-2005, 11:48 PM   #8
ABHaulR
ABHaulR's Avatar
conversion
you can buy the new crossmember with the brackets for the trailing arms on them allready.you have to redo your brake lines, they come off the frame at the crossmember, panhard bar mounts on the frame and the rearend housing.you'll need to redo the spring perches, they set at an angle that matches the trailing arms. also the perches have holes in them for a single u-bolt. you'll need the attachment pad for both the trailing arms and the frame. hope this helps.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
