01-25-2005, 01:26 AM | #1 |
Embrace the Redneck
clutch problem?
What is the proper length of the V8 clutch z-bar??
I have both of the bars, one from a I6 and the other from a V8. Which is the propper one, the longer or shorter one?? thanks, sswj
'01 Camaro Son, you just can't get there from here... |
01-25-2005, 05:49 AM | #2 |
I think the V8 Z-bar is shorter than the L6 type because the base of the V8 block is wider. Don't remember if the levers are longer, I was refering to the tube dimension. I have a spare L6 Z-bar I could measure tomorrow.
01-25-2005, 07:24 AM | #3 |
Watch out for your cornhole !
I also have one of each if you need me to compare them and measure.
01-25-2005, 08:59 AM | #4 |
Embrace the Redneck
i need the measurement of the V8 tube. which one do i use on a V8?
01-25-2005, 07:04 PM | #5 |
Embrace the Redneck
ttt
01-25-2005, 07:31 PM | #6 |
Fabricate till you "puke"
6 5/8".... (so my longhorn says). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-25-2005, 08:04 PM | #7 |
Embrace the Redneck
thanks, i think it's the shorter one of the two.
thanks, keep the comment's rolling. i need this confirmed. sswj
01-25-2005, 10:48 PM | #8 |
Embrace the Redneck
it's the longer one. I got it to hook up fine.
sswj
