01-25-2005, 10:15 AM | #1 |
Weekend Warrior
[B]Another "What's it worth"[/B]
Sorry guys i'm just curious as I can't make up my mind about anything anymore....
'69 SWB chassis with: -2.5" ECE dropped spindles -4" ECE dropped rear springs -ECE Rear shock relocator kit -ECE Adjustable Pan-Hard Bar -New MOOG Upper and Lower Ball Joints -New MOOG Pitman and Idler Arms -New MOOG Inner and Outer Tie Rods -New MOOG Upper and Lower Ctrl Arm Shaft Kits -'73+ PowerSteering Box -'73+ 5 Lug Discs -All the new Chassis stuff is for '73+ (cause it is cheaper and easier to get in junkyards) with the exception of the Upper and Lower Ctrl Arm Shaft Kits (which are for the 67-72) and the Rear Springs and stuff -Rear is Open Carrier 6-lug (gonna say 3.08's but i can check this weekend) -6cly motor mounts, no tranny crossmember, but i can include a set of small block mounts and an auto x-member Chassis is in very good condtion - no "rot thru", no major "pitting" with the exception of the Right Rear Trailing arm...and the only problem with that is that the two sides are seperating....i can cut the spot welds out and re weld it back together and it would be fine. None of this is put together (all New Parts still in thier boxes - I painted the Dropped spindles black though) - the chassis is rolling on the old front end parts as of now. It has not been cleaned/sandblasted - as i was going to clean it and use either POR15 or Eastwood's Rust Encapsulator on it. So if you wanted it powdercoated it is still in "virgin" form Any ideas on what it would be worth - i'd put it together and Paint it with POR or Rust Encapsulator if someone wanted. more than $1200 just in parts/shipping for the "new stuff" ???????????????? Thanks, Andy
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 01-25-2005 at 06:22 PM. |
01-25-2005, 06:21 PM | #2 |
Weekend Warrior
No one?
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-25-2005, 06:52 PM | #3 |
my gas saver
depending where you got the front end parts, i would return everything you could for full price, if it was a local part store (napa, autozone???) if that`s not an option, i would sell it as a complete kit to someone. then i would sell the spindles. and the only thing i would really know the value of would be the roller frame ($150-$300) or so. i have bought 2 of them in the last few months.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
