Old 01-25-2005, 12:48 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
'72 3/4 Ton Rear End, Located in SW Virginia
'72 C-20 3/4 Ton Rear For Sale. Still in Truck, $200, Includes Take Out. PM or Reply For More Details.
C10 - C90 Bill is offline   Reply With Quote
Old 01-25-2005, 09:45 PM   #2
billsbowtie
billsbowtie's Avatar
hey there where is moneta va. i am in rose hill va. very sw va.
billsbowtie is offline   Reply With Quote
Old 01-25-2005, 11:39 PM   #3
C10 - C90 Bill
22 Miles East of Roanoke, in Bedford County.
Old 01-26-2005, 12:15 AM   #4
Do you know if it`s Dana or Eaton(round pumpkin)?Leaf or coil?
Old 01-26-2005, 08:38 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
How about the gear ratio.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-27-2005, 08:39 AM   #6
What color?No,serious,need more info,plz.
Old 01-27-2005, 02:53 PM   #7
C10 - C90 Bill
Rear has leaf springs. Having a hard time identifying the type. Checked my Hollander, Chevy Truck Parts Book and a Chiltons, but couldn't find an illustration. Anyone know of one on line? Also does anyone have any GM codes to determine ratio? Don't want to take off the cover just yet if I don't have to. Anyone interested can also PM me for an E-mail address if they wish. Bill
Old 01-27-2005, 04:45 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Is the cover round w/ a drop out center section? If that's what you meant by take out, then it's an H052. Probably 4.10 gears, could be 4.56 or 5.13 though.
Old 01-27-2005, 05:10 PM   #9
C10 - C90 Bill
Jim, It is a non-remove-able carrier. The cover has about a dozen or so of flat edges on it. Also by "Take Out", I meant removing the rear from the truck will be included with the price. Bill
Old 01-27-2005, 05:19 PM   #10
1969 GMC
1969 GMC's Avatar
sounds like a dana 60 to me.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-27-2005, 07:10 PM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yep that would be dana 60. Do you know if the truck was a big block or not? Then the ratio could be 3.54.
Old 01-27-2005, 08:05 PM   #12
C10 - C90 Bill
I'm not sure what was in it, but it sounds a little familiar that the guy I bought the truck from said "400 Small Block". Anyone know of any other way of telling? There is also no front clip on the truck, therefore original sticker under the hood is long gone.
Old 01-27-2005, 08:38 PM   #13
The 400 small block wouldn`t be original.Does the truck hae the glovebox door with the options list?To figure ratio,put marks to align yoke & housing,then mark brake drum & backing plate.Spin drum,counting revolutions of yoke `til the drum makes one turn.Just over four=4.10,about 4 1/2=4.56,etc.
Old 01-28-2005, 02:58 PM   #14
C10 - C90 Bill
Just talked to another friend this morning and he seems to remember the truck being a 350. I never knew a 400 SB was not offered in these trucks. Always learning something new. Anyway, I believe the truck still has the option list on the glove box door, but is a little hard to make out. Will check it for a ratio.
special-K, I've tried that trick of spinning the drum and counting the driveshaft before, but have found it to be only accurate on posi-traction cars. Haven't verified it, but remember being told by the guy I bought it from that it was not a posi rear.
Old 01-28-2005, 09:01 PM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If it's non-posi then you'd double the number or rotate the tire twice and count the total driveshaft rotations.
Old 01-28-2005, 09:43 PM   #16
C10 - C90 Bill
That makes sense Jim, as the last time I checked on one that turned out to be a 3.08, it turned only 1 1/2 times. Appreciate the info.
Old 01-29-2005, 02:59 PM   #17
C10 - C90 Bill
Got a chance to check the glove box door and sure enough it lists the 350 engine with a Turbo-glide trans. But nothing about a gear ratio, just something about heavy duty leafs.
If y'all still would like to know the gear ratio, it will take a little longer as it's starting to snow and we may get a possible 10 inches. So far all year all we have got was 2 inches. Don't really like snow!
Old 02-01-2005, 04:55 PM   #18
C10 - C90 Bill
Finally got a chance to check the ratio. It looks like it's a 4.10. It's a non-posi, I turned the wheel 1 full time and the yoke went around a tad bit more than 2 full turns. Times 2 equals 4.10. Bill
