Old 01-25-2005, 01:10 PM   #1
Peregrine
Peregrine's Avatar
Stock height
I was wondering what the stock height measured from the top of the wheel well arch is on our trucks. I more pictures I see of dropped trucks, the less I think it's a 3 inch coil cut in the front, and I'd like to figure this out once and for all. I know wheel sizes make a big difference, but that's ok. I could find the differance if you would be so kind as to tell me what size tires your running. Or the size of stock 72 c10 tires.
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 01-25-2005, 02:40 PM   #2
uk72step
outta the car velocityboy
uk72step's Avatar
hey buddy, factory specs should be:
FR: 32"(top or arch to ground)
RR: 34"
If you have an LMC catalogue (p95) it shows you the measurement and ideas for different stance etc.. hope this helps
just wanted to try a new smiley....
Cheers
Lee
..give it a turn here, take some wedge out there, we'll win some races...
uk72step is offline   Reply With Quote
Old 01-25-2005, 03:42 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
That measurement won't do you much good unless you have the original tires on the truck. Measure from the center of the wheel to the top of the wheel arch. From past discussions, we concluded that the front should measure 19" and the rear should measure 22". This will give you a more accurate measurement of the amount of suspension drop regardless of tire/wheel size.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-25-2005, 04:43 PM   #4
Peregrine
Peregrine's Avatar
Thanks to both of ya. And the rear is 3 inches higher than the front? Weird.
Brian
Old 01-25-2005, 04:48 PM   #5
GMC AMI
GMC AMI's Avatar
Cool Hey, who let the air out of my truck?
Here is a PIC
A real low rider!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
