Old 01-25-2005, 01:41 PM   #1
1969K10
1969K10's Avatar
Crossover Steering On Closed Knuckle
So, has anyone done a crossover steering mod to a closed knuckle (D44)? It doesn't look hard to do, just make a new top plate for the pass. side knuckle, and the crossover steering link...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-25-2005, 04:55 PM   #2
1969 GMC
1969 GMC's Avatar
Why? If you need crossover, it means you are lifting the truck, which means bigger tires. I don't know about you, but when I dd'ed my '69, I thought the front drums were ok for driving around. But loaded, or offroading, it was another story. When they got wet....
Especially with bigger tires...I wouldnt trust the drums. Just my 2 cents
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-25-2005, 06:07 PM   #3
1969K10
1969K10's Avatar
1969 GMC - Awesome signature Anyhow, you are correct this is a DD, but I like to play with it also, which is why I'll slowly be putting together another truck. I was just thinking that it would allow for some more suspension articulation w/o trashing the steering box and its mount to the frame. Also, I'd like 2" (maybe 4") lift, no more than req'd to fit 35X12.5's w/o worrying about rubbing a tire. It was just one of those things I was looking into doing for S&G's. You're right about drums not stopping well when wet!!!
Old 01-26-2005, 08:34 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
2-4" of lift might not give you enough room for crossover.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
