01-25-2005, 06:04 PM | #1 |
1/2 ton and 3/4 ton
What are the differences between the two? I'm assuming that the 3/4 has leaf springs instead of the coils, but does everything else bolt up? I've got a neighbour with a 67 1/2 thats beat to **** but has a good chassis and I'm looking at a 3/4 that would work out great if I could transfer the drivetrain and interior over
01-25-2005, 06:48 PM | #2 |
The drive train and interior are the same. The only difference is the suspension and rear end. My 3/4 ton has a Dana 60 and 1/2 doesn't have anything that heavy duty. All the body parts bolt right up from a 1/2 to 3/4 ton. The only problem with the drive train would be the transmission hump in the cab if were going from auto to stick or the other way around.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside 350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb Beaverton / Portland Oregon |
01-25-2005, 08:34 PM | #3 |
there are some coil rear chevy and gmc 3/4 tons.I have a 3/4 ton gmc with rear coil springs in it.
01-25-2005, 09:08 PM | #4 |
its all about the +6 inches
Basicly, a 3/4 ton is exactly like a long wheel base 1/2 ton with the exception of;
Rear end spindles hubs springs (leaf or coil...both were avalible) front suspention parts (ball joints and stuff) Body mounts badges If memory serves...that is about it. |
01-25-2005, 10:15 PM | #5 |
Watch out for your cornhole !
There is a little mis-information about the differences between the two.
See this thread for some pictures I posted comparing the differences between the 1/2 and 3/4 ton frames. There are some differences. http://67-72chevytrucks.com/vboard/s....php3?t=137109 Down toward the bottom of page one and then page two.
01-25-2005, 10:48 PM | #6 |
Woah....thanks Tx.
01-25-2005, 10:56 PM | #7 |
And I was trying not to learn anything today. I almost made it but you had to go and ruin it.
Oh well...I'll try again tomorow. |
01-25-2005, 11:08 PM | #8 |
Mine has HD coils specified on the glovebox, it rides kinda rough without a load in the bed. The only downside to coils is that when they get old and worn out, they'll sag and then you gotta replace 'em.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
02-19-2010, 12:12 AM | #9 | |
Re: 1/2 ton and 3/4 ton
1968 LWB C20 / AC / Wood Bed |
02-19-2010, 12:37 AM | #10 |
5 years dead
02-19-2010, 01:12 AM | #11 |
Well it served it's purpose again. I learned something new today.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
