Old 01-25-2005, 11:50 PM   #1
Bob Moore
Question Odd part
I have been playing with trucks for about 13 years now and saw something today that I don't recall seeing before. Local junkyard got in a 73 Suburban - nothing unusual at first glance however on the second go round it got wierd. Glove box sticker said Model 10906 - 1/2t burb 2 wheel drive. Listed a 454 V-8 (no problem). Looked under the hood - there sits a non-Chev motor that has the hei mounted up front and an almost recessed intake manifold - maybe Buick - but doesn't look like most Buicks i've seen. This thing looked so good it looked FACTORY installed. I have seen some pretty messed up swaps but this was good.
Now for the odd part. The motor mount stands or frame stands were totally
different than the normal P/U or Burb 2wd pieces. These things "looked factory" stamped with ribs and everything but were way longer(front to back) than normal - they had 3 bolts to mount to the frame and went forward to pick up the mounts of this engine.
Are these diesel pieces that somebody used? I guess I haven't looked at too many diesels to know if this part changes for gas engines. Anyway it was a different part than I am used to seeing.
Can anybody shed some light on this?
Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-26-2005, 02:08 AM   #2
jimfulco
Cadillac?
jimfulco is offline   Reply With Quote
Old 01-26-2005, 06:38 AM   #3
plumbcut
california fill
plumbcut is offline   Reply With Quote
Old 01-26-2005, 10:54 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
An Olds V8 can be mounted using the brackets for an early diesel.
I used to know a guy with a Pontiac 400 in a C10. He said that he used motor mounts out of the donor car, and they bolted right up. I never looked at how it was mounted in the frame, so I don't know anything more about it.
Also, like someone else said, I have heard there are kits available to put the big Cadillac engines in C10s.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-26-2005, 11:14 AM   #5
60-66 Nut
Professional Beer Tester
Olds engines(and Pontiac too, as I recall) have the distriutor at the rear, so it would probably be either a Buick or Cadillac motor. Sure would like to see some pictures of it. Actually, it would be nice to see ANY pictures. Don't know what I'm doing wrong, but I still can't open any pics. I tried adjusting my browser settings, but still nothing.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-26-2005, 01:46 PM   #6
Bob Moore
I know pictures are wonderful but it was supposed to be a day at the junkyard - I didn't expect this. Will have to start carrying camera all the time.
Sorry - Bob
vac, 454, T400
more to follow
Old 01-26-2005, 04:02 PM   #7
gn4u2c
gn4u2c's Avatar
most likley a buick mtr and the buick mounts sit it in bolt to trans drill new mount holes bolt it down DONE> wire and plumb your done.
gn4u2c is offline   Reply With Quote
