Saving 1 truck at a time!
Rearend ID
I know we have been through this before but I lost the link. I am trying to ID the rearend in a '72 Longhorn. It has a tag and a casting number. I only have '67 service manuals and it looks like a GM with removable rear cover (10 bolts and drain plug in cover). Casting number C-30255 and tag number 461 above 354. Any clues?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
huh ???
Eaton
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
DANA 60: The 60 looks deceptively similar to a Dana 44, but the 60's 9 3/4-inch ring gear diameter is a major factor in strength. It can be found in many 3/4-ton pickup and van rearends.
DANA 70: Almost identical in appearance to a Dana 60, the Dana 70 is standard in heavy Dodge pickups and GM duallies. The large 10.54-inch ring gear diameter will tolerate much torque, and is suitable for diesel power and/or big tires. Eaton:Big & round... kinda like my ex-monster-in-law's backside! ![]() PICS:Eaton left/D-60 middle/D-70 Right Last edited by Americanrider; 01-26-2005 at 03:58 AM. |
Americanrider...thanks for the pics. Looks like a Dana 60 since this is a 3/4 or 1 t. Longhorn. I will call Randy's Ring and pinion to see if they can tell me more about the tag number. Thanks guys.
