Old 01-26-2005, 02:17 AM   #1
thisolechevy
Question gauge cluster wiring problem...HELP
Hi all I converted (or atleast I am trying to) from the old idiot lights to the full gauge cluster and I am having problems with the wiring and them not working properly. I got some info. on this forum and a print out sheet with all of the correct wiring digrams for the conversion but mine still doesnt work right. the gauge that even attemps to "work" or move is the fuel gauge and it spins when I use the starter but when I release the starter after the motor cranks it stops where it is???? whats up with my cluster wiring? any help is greatly appreciated!!
Thanks, Brad.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 01-26-2005, 05:57 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You didn't rewire the harness plug did you?
Even though the plug is the same, the harness is different.
And your fuel guage...it's junk now...ask me how I know.
Old 01-26-2005, 11:10 AM   #3
thisolechevy
I did re-wire the plug the sheet I recieved had you rewire the plug and then it should of all worked is what the paper said. Did I do something wrong? and what do you mean junk...I am scared now...what happened to yours? longhorn man
Old 01-26-2005, 08:38 PM   #4
Longhorn Man
Sounds like you were putting power to the ground terminal on the fuel guage. It'll probably never work again. The good news is they are pretty cheap on the parts page...10 bucks oughta get you one.
Old 01-26-2005, 11:37 PM   #5
Hooter
My other Love
Hooter's Avatar
well you re wired the plug, but did you get the right temp sensor, because the sensor for the idiot lights is different, and you have to run another wire for the ammeter to work because it works by sensing the current drop between two areas, and I should hope your oil guage is working because thats just a hard copper line, if that doesnt work, then you really done something wrong, did you hook up the grounding strap on the back of the cluster to the dash, that is another common mistake people do, i forgot to hook it up in my Monte Carlo when I did the tach conversion in it, its easy to miss
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
