Ultimate Diesel Dude
I need new weatherstripping around my doors and windows....getting lots of wind noise and water leaks in hard rain.
JC Whitney is offering this kit which has two door seals, two window channel seals, and four belt-line moldings (the pieces at the bottom where the window and door meet) for $134.95. I also have a 10% coupon I can use on top of that. Is this a good deal? Is this good quality material? Or can I do better? Thanks! Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
I don't know about Whitney but Softseal is hard to beat.
i got the front wondow kit and the rubber was too hard for the installer to put in. the original was still in good condition after i cleaned it up. i dont think you will have a problem with that on the side windows
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
Professional Beer Tester
Don't know if they would be from the same manufacturer or not, but I put a set of J.C.Whitney door gaskets on an '88 GMC S15. They fit OK except for the upper rear corners, the S15 had square corners and the gaskets did not have any pre-shaped corners like the originals. The 73-87 fullsize trucks have rounded corners so that shouldn't be a problem.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
Slots go on anything!
I used a kit from JCW on my 73. It fit pretty well. The biggest problem I had was with the vent windows. I had an oem rubber as well, and it wouldn't have mattered, I would have butchered either part. I found a nicer set in the junkyard on an 86 Blazer and went that way. The rest of the weatherstripping fit just fine.
1974 Jimmy- 5.3/4L80e/NP241 |
I am am going to order the same kit. The company that makes it is called Precision Weatherstripping.
Not only do you get the $10 Gift Certificate but if you order today you get free shipping.
83 Chevy SWB http://www.cardomain.com/id/letheridge |
I just ordered the weatherstripping kit and got the free shipping. Saved 16.99 but the $10 gift requires you to sign up for some shoppers discount website. Just thought you should know. When I get them in my truck I can tell you how they fit
I tried to used the window runs before and they were crap. Found them at the dealer for the same price. I wish I would have tried there first. Had a heck of a time getting refund from JC.
I've used the door and window strips from JCW. The door seals fit fine and still looks good after 2 years. The window channel strips are poor fitting. Next time I'll go GM on those.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
#10 | |
Hey, 83C, I was just wondering if you have had a chance to install that weatherstripping yet? Casey
i got window channel weatherstip from jcw, i dont know if i didnt do it right or what but seems to be to tight at the top of the window, becomes very hard to roll up
Brian |
#12 | |
I've managed to free up the driver's side, but the pass. side still gets tight in the bottom half of winding down. I think I'd try someone other than JCW for weatherstripping. They don't leak and fit well, but are too tight. Shipping was good, though- I lived six miles from their warehouse at the time and picked 'em up myself!
Semper Paratus |
