01-26-2005, 01:11 PM | #1 |
Looking For A Nv4500 Or Nv5600 Tranny
ANYBODY OUT THERE HAVE A NV4500 (5 SPEED) OR A NV5600 (6 SPEED) TRANNY THAT THEY ARE WILLING TO PART WITH???? JOHN AT FK9U812@AOL.COM
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-26-2005, 09:20 PM | #2 |
Hi John,
PM kwmech, I think he has a NV4500 he was trying to sell
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
01-26-2005, 10:39 PM | #3 |
It's a 4wd trans set up with a 205-thanks ljbear.
01-26-2005, 11:39 PM | #4 |
I might be interested in that 4x4 setup with the np205, can you give me more details kwmech? Provided that Junkyardjohn don't want it.
01-27-2005, 12:47 AM | #5 |
i could be interested in thr 4500 to, put me behind the other two thanks
Ryan |
01-27-2005, 08:36 AM | #6 |
I`d be interested to know what is involved in the coupling of a NV4500 and a NP205.Or,just put me in front of the others,I`ll take that one.HaHa!
01-27-2005, 10:03 AM | #7 |
Here's some information on the swap; http://67-72chevytrucks.com/vboard/s...threadid=35373
01-27-2005, 11:44 AM | #8 | |
01-27-2005, 03:05 PM | #9 |
Kwmech,
PMed' you
01-28-2005, 06:59 PM | #10 |
Ttt
01-28-2005, 08:47 PM | #11 | |
junkyardjohn; I have a 2wd NV4500 I might be selling. Depends on if I can work out a deal on a 4x4 version a friend of mine has. I don't know of a way to ship it though.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-28-2005, 10:04 PM | #12 | |
Actually the bellhousing pattern I was talking about is where the trans bolts to the bell. I should've been more specific. I know the dodge nv4500 and the 96-up chevy nv4500 has the same bell to trans bolt pattern. Just wondering if the nv5600 is the same.
01-28-2005, 10:25 PM | #13 |
THATS AN EXCELLANT QUESTION. ONE I'D SURE LIKE TO KNOW SOME ANSWERS TOO ALSO. THANKS JOHN
01-29-2005, 01:06 AM | #14 |
BUMMER... DOES THE NV4500 HAVE THE SAME BOLTPATTERN ON THE BELL HOUSING THE OLD TRABNNYS?? IN OTHER WORDS WILL IT BOLT UP TO A PRE 85 SMALL BLOCK CHEVY?? JOHN
01-29-2005, 01:19 AM | #15 |
Watch out for your cornhole !
John, call Standard Transmission. They have a website too.
I've been using those guys for 14 years now for all of my hand shaker trans needs. They specialize in NV4500 and NV5600 transmissions. They are on the up and up. Since they're local, I drive over to the shop when I buy a gearbox from them. Great shop, clean, reputable. You can trust them.
01-29-2005, 01:25 AM | #16 |
The nv4500 won't bolt up to the older 3-4 speed bellhousings. But the bellhousing for the nv4500 will bolt to any "normal" older small/big block. Hmmm.. does that make sense?
Let me try again, The nv4500 has 2 different trans to bellhousing patterns, neither of which is the same as the older 465 trans. 92-95 external hydro slave cylinder (bigger trans to bell pattern than the 465) 96-up internal hydro throwout bearing.(same trans to bell pattern as the dodge nv4500) Both styles of the nv4500 bell will bolt to any normal small/big block chevy engine. nv4500 does uses the same clutch setup as the old 465, (10 spline, 1-1/8in input shaft) Advance adapters makes a bellhousing that has the mechancal clutch linkage and the correct bolt pattern for the nv4500 but it's just a tad spendy IMHO. $375 or so.
01-29-2005, 03:37 AM | #17 |
I'm passing the deal to ryanroo, he's next in line... just not in the cards for me right now.
