Old 01-26-2005, 02:37 PM   #1
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ball Joints not letting me grease them?
I went out to grease up my '88 LongBox Pickup yesterday. I think I was trying to grease the ball joints on it. I am not used to the whole IFS thing but they were in the same place that my ball joints on my Blazer are at.
Anyways I cleand up the nipple on them and got my grease gun on it, but there was alot of resistance so I figured I would just squeeze it really hard and it would work. But instead grese came squirting out of the rear end of the grease gun.
Anybody had this happen before or have any suggestions on it.
Thanx for any advice!
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-26-2005, 03:04 PM   #2
1-PU70
1-PU70's Avatar
Heres what I used to do when I worked for the city, hope it helps. First remove the greese fitting to make shure its not cloged, then with a pick or something simmalar dig out as much old greese as you can from where the fitting was. Then squart som penatrating oil in there, replace the fitting and greese. You might have to do this a couple of times but it always worked.
Good luck
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
