Old 01-26-2005, 07:03 PM   #1
67chevemall
67chevemall's Avatar
stuck on the steering gear?
I took the 4 bolts off the frame BUT there is a big nut on the
pitman arm that I forgot about.
Which bolt do I take off? Which end of the pitman arm?
The one end has a cotter pin though it.
I think the one directly under the steering gear or box is the one
I should take off but not sure if it even a bolt it is so gummed up
What size nut would that be 22mm? 3/4"??
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-26-2005, 07:54 PM   #2
60-66 Nut
Professional Beer Tester
The pitman arm should have a 1 5/16" nut holding it on, then you should really use a pitman arm puller to get it off. Beating or wedging it off can damage the gear internally. To remove the pitman arm from the center link, I remove the nut(13/16 or 7/8 I think) completley to clean the threads then start it back on the stud about halfway to keep the threads from getting hit. Then I smack the center link right where the pitman arm stud goes through it. They usually fall right out. Good Luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-26-2005, 08:19 PM   #3
67chevemall
SO take the cotter pin out and loosen that big nut and take the other nut
off the center link once it is out of the truck?
I can't get a puller so I'll have to "smash" it out.
I'll have to put the frame bolts in to hold the SOAB.
Old 01-27-2005, 10:11 AM   #4
60-66 Nut
Sorry if I confused you, I stay confused and sometimes it's contagious. You can just leave the pitman arm on the box, remove the cotter key and the nut on the center link and separate the pitman arm from the center link. Let us know if that works.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 01-27-2005, 02:28 PM   #5
67chevemall
I got the thing cleaned up and the cotter pin out, but I have to buy
a set of LARGE wreches!! I don't have a socket that big either! $%&#*!@#
That is one tight nut!
I try again tonight
