Old 01-26-2005, 09:54 PM   #1
franko72
Franko72
franko72's Avatar
72 emissions
My 72 truck doesnt have the evaporative charcoal canister for the fuel sytem.Did they come on the 72 super cheyenne w/402?There isnt any type of emission parts that I can see.I know that everything tanked in 73 .I am trying to replace the fuel lines were the dealer added an extra saddle tank on the passenger side. They installed a lot of rubber tubing hose that is getting old and leaking at some fittings and clamps.I noticed an extra line that was not connected.a diagram would be great if someone could show one for fuel line routing on the 72.the tank does not have a return line.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 01-27-2005, 06:41 PM   #2
franko72
Franko72
franko72's Avatar
come on experts, I know someone out there has an answer , fake it if nothing else.
My Home Page
Old 01-27-2005, 06:45 PM   #3
rustyold72
rustyold72's Avatar
Didn't think 72 light trucks had any type of emissions control devices
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 01-27-2005, 07:31 PM   #4
tom hand
CCRider
tom hand's Avatar
The smallblocks had the evaporative charcoal canister in 72...so I would think the big blocks had it
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 01-27-2005, 07:55 PM   #5
COBRO
Active Member
Lightbulb
I think the smog crap was a hit or miss in 72. My 72 C-20 with the 402 didnt have any other than the PCV valve and the breather in the other valve cover plumbed into the air cleaner. Most dont realise that the PCV valve was the first of the smog equip. Just wondering if the hose you found my be a vent hose for the tanks. HTH::::::COBRO
COBRO is offline   Reply With Quote
Old 01-27-2005, 08:20 PM   #6
JimKshortstep4x4
Smile
The C-10's had the emissions setups but the C-20's and larger did not have them.
Engine size was not a consideration as all of the C-10's had the emissions
setups in 72. I am not sure what year emissions controls other then pcv's were added but I believe it was in 1970.
Jim
Old 01-27-2005, 10:29 PM   #7
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Check the fuel neck and the cab, if there is a metal line that runs up the cab corner on the passenger side into the roof and an over flow tube on the filler neck then the truck came with emissions, also there is a metal line that runs beside the fuel pump line on the frame towards the battery,
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 01-28-2005, 05:15 PM   #8
franko72
Franko72
franko72's Avatar
All I have is the PCV .The line that is loose is a return line that was never used I think.
My Home Page
Old 01-28-2005, 05:37 PM   #9
HOTFUN
HOTFUN's Avatar
Jim is 100% correct. The emission systems were GVW rated and the 10 series all had them small or big block and the 20 series did not. I have both a 10 and 20 big block and the 10 has both the smog pump and charcoal can. The 20 series does not and you can tell by the non ported exhaust manifolds where the air pump tubes attach on the 10 series. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 01-28-2005, 07:01 PM   #10
tom hand
CCRider
tom hand's Avatar
I believe the air pump was a California thing only in 72...the 49 state 72 trucks had the evaporative charcoal canister,PVC,and the transmission controled spark that only allowed the vaccum advance to work in high gear
Olive Branch MS
Old 01-28-2005, 07:31 PM   #11
avejoe
Custer had a plan too.
avejoe's Avatar
OK, so can all of this stuff (fuel vapor lines, cannister, spark control, PCV) be eliminated?
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 01-28-2005, 07:36 PM   #12
69sixpackbee
My '72 C-20 402 DOES NOT have anything for emissions with the exception of a vented gas cap and a PCV valve. That's all it ever came with.
69sixpackbee is offline   Reply With Quote
Old 01-28-2005, 08:00 PM   #13
Harold Shepard
The return line is not for gas (liquid) but vapor return. If you have a 10 series 72, you will have at least a vapor canister (charcoal canister) that attaches to the metal line on the frame, EEC,which this line hooks to on the gas tank the transmission spark retard and PCV. If equiped with California emissions package, it will also have the smog pump and AIR lines.
Harold Shepard is offline   Reply With Quote
Old 01-29-2005, 11:57 AM   #14
franko72
Franko72
franko72's Avatar
wonder why the C 20 s didnt have the canisters with the vapor return and smog pump?
My Home Page
