01-27-2005, 06:18 AM | #1 |
How To Shorten GMC Frame??
I think this question has been asked before, but I couldn't find an answer to it. Does anybody have any dimension of how much to shorten the frame on a leaf spring frame behind the rear perch to convert to a SWB? The center has already been done.
01-27-2005, 06:39 AM | #2 |
You'll find lots of info in the FAQ section.
http://67-72chevytrucks.com/vboard/s....php3?t=123624
01-27-2005, 07:13 PM | #3 |
I have a leaf spring Chevy I cut 8 " off and I think I would start with 6" next time I would have like to have a bit more steel under therear cross sill. The frames are the same lenght coil or leaf. 8 " is what they say needs to be cut off. But 6 is playing it safe. You will need to drill a hole in the back of the frame for your rear cross sill to bolt into also.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-28-2005, 07:17 AM | #4 |
72Mario,...............
Mario,
How much did you remove from the center? 12"? Thanks, |
02-12-2005, 06:25 PM | #5 |
Yep 12" from under the cab.
