01-27-2005, 04:08 PM | #1 |
My son, my joy.
Anybody want to trade some work for parts?
I really need to swap out the front end of my truck for a newer power disk setup. This seems like a logical thing to do instead of putting a bunch of money into fixing the original setup. I have two badly worn drums up front which cost about 100 bucks each new. Can't find used. I also have a bad spindle and hub from a bearing that committed suicide and decided to take out some other parts with it. It just makes sense to me to try to upgrade to power disk.
It's a 69 3/4 ton small block truck. 8 lugs. The problem is, I just cannot scrape up any money to put into it. So, I was thinking, if someone in the Spokane WA area has a later 3/4 ton parts truck laying around with good rotors and stuff, maybe I can do some work for you in exchange for the front end out of it. I'm about ready to go to a busy intersection with a sign "Will work for truck parts!" |
01-27-2005, 08:41 PM | #2 |
I will be updating a 67 3/4 ton to 1/2 ton in the future, hopefully soon. I do not know what the drums look like. I am kinda far from you too.
01-29-2005, 10:12 PM | #3 |
My son, my joy.
Well, I hadn't thought about finding some used drums. The only problem is, I would still need to replace the spindle and hub on one side. I'd rather put my efforts into converting it.
01-29-2005, 11:26 PM | #4 | |
also have a complere front end from a 71 new disc,,,,the whole work's steering linkage...the complete sub frame....make a offer....5 lug there... got 5 ralley wheels to match.....cap's and trim rings..... road trip Last edited by rage'nrat638; 01-29-2005 at 11:30 PM. |
01-30-2005, 12:41 AM | #5 |
parts
Cat Fuzz, I am in the Boise area, I have a good front end from a 68 3/4 2wd power drum truck, drums, spindles ,a arms ,steering link, tie rods, and master cylinder, they worked great when removed, hows $100 for everything you pick up, veltex
beater 65 gmc at the moment |
01-31-2005, 05:55 PM | #6 | |
My son, my joy.
This sounds like a good deal. I'll have to see about getting another truck besides my own for the long freeway drive. My dad has a little *ord *anger that would get much better gas mileage. Lemme check into it and I'll get back to ya. |
02-19-2005, 12:39 PM | #7 |
My son, my joy.
Update...
I got a hold of the local guy with the 73 Burb. He still has it and I think all I have to do is strip it down and haul off the carcass for him and I get the front end and m/c, booster for free. YIPPY!!
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400. Founding member of the No Money To Spend On My Truck Club. When your at Home Depot, you WISH you had gotten an 8 foot bed! |
