Old 01-27-2005, 08:30 PM   #1
me3
hart
Question v8 to 6 swap
well its the old mans truck and we just need anoughter driver. 85 4x4 4spd originally a v6 plain jane power steering power brakes. so will the mounts work the 350 fit just fine. I think my inline is a 250 have to see if its not a 292. if i remember right 292 has offset mounts. 350 to inline geez old man must be getting old.
me3 is offline   Reply With Quote
Old 01-27-2005, 11:53 PM   #2
EricS76
EricS76's Avatar
I'm not sure about the V-6, but it should use the same mount as the 350. If so, then the 250 L-6 will use the same mount, but you'll have to move the mounts to the lower position on the motor-mount mounts. You're right about the 292, it uses offset mounts.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 01-28-2005, 09:59 AM   #3
gldevall
gldevall's Avatar
If it's a 4.3 V-6 then the mounts are different than the ones for the 350. When I swapped out my 4.3 for the 350 I hade to change the motor mounts and the towers. They were all different.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 01-29-2005, 12:46 AM   #4
me3
hart
well its got a 350 right now so moter mounts will be the same im not moving the trans and transfer case for sure dont want to mess with a drive shaft so im going to try to drop it in the eight positon its probably in the six now anyway.
Old 01-30-2005, 12:25 AM   #5
me3
hart
well I pulled the 350 today to find it setting on v6 mounts (no crossmember). the inline 250 I plan on putting in has the three bolts for the mounts turned around one on the top and 2 on the bottom(exact opposite of the v8. so ? is if I go to the priceless artifacts yard sometime this week to find the crossmember will a v8 work? I understand they came out with a 250 till 84 but finding one will be near impossible. This is a 4x4 truck. I think its time to go get a 12 pack.
Old 01-30-2005, 03:10 PM   #6
me3
hart
bump
