WHYBYNU when old will do
I need a little advice..
I noticed that the outside bolt hole on the mounting pad for the starter is cracked and was wondering what is the best way to repair this? Isn't this fairly common? I've heard of it just never seen it before.
Thanks, John
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
A stick shift will fix it.....starter bolts to the bell
Thanks for the reply. Thats what I will do. You have to love these trucks because it's alway one steps forward and two steps back....
Thanks, John
Yup, anything that is 30+ yrs old can cause problems.....been there too many times to count
Watch out for your cornhole !
![]() Join Date: Jun 2003
Here is what I'd do personally.
I'd get the little bracket from the dealer that goes on the front of the starter and bolts to the block. Some later model vehicles used it. It bolts to an empty bolt hole on the side of the block. Then, I'd tighten the one good bolt plenty tight and the cracked bolt as tight as I thought I could get away with. My money says you wouldn't have any problems with it, doing it this way. Over the years, when swapping starters, I've run across several with one of the starter bolts complately missing. I'd assume they were just left loose and then fell out later. The whole starter just held up by the remaining one bolt.
It's a catastrophic success.
![]() Join Date: Jan 2003
I used a longer bolt to reach the good threads but you still may find that the starter will flex or have shim problems.
