01-28-2005, 04:44 AM | #1 |
Epoxy Primer Friendly
Are 71-87 lower control arms the same ?
beside the balljoints ?
01-28-2005, 08:54 AM | #2 |
Pre-73 arms use solid, rubber lined, screw type bushings. Post-73 use thicker, rubber type press-in bushings.
