Old 01-28-2005, 02:36 PM   #1
Daubs
Daubs's Avatar
Making a K10 into a K20?
Really like the way 3/4 ton's look = 16 inch rims, eight bolts, etc.
Having trouble locating 3/4 ton 4x4 and wondering just what difference between the two besides axels, shocks, leafs and maybe different frame. Obviously different emissions and engine / tranny combo in the heavier trucks.
Is it as simple as swapping axle's out? What else?
My ultimate goal would be a 4" lift with 16 inch rims, AT tires.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 01-28-2005, 02:46 PM   #2
Mudder
Mudder's Avatar
Personally I would look for the newer axles with disk brakes.
Mudder is offline   Reply With Quote
Old 01-28-2005, 03:59 PM   #3
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Yeah the 3/4 tons are nice, but I kinda like the 1 tons with the big block
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 01-28-2005, 05:29 PM   #4
1FaastC10
1FaastC10's Avatar
frame is identical. if you can find a set of 73+ K20 axles, they should bolt right in no problem.
1FaastC10 is offline   Reply With Quote
Old 01-28-2005, 06:10 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
The 73+ K20 axles will require the spring perches to be moved for the rear axle. 73+ K30 rear axles have the correct width spring perches.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-28-2005, 08:43 PM   #6
b454rat
Depending on what year your truck, everything will bolt on. If you have a 67-72, any year front will bolt in. But the only real difference in a 1/2 to 3/4 ton is the 8 lugs. Innards are the same, brakes are the same, axles are the same. You could take an 8 lug setup from the ball joints out and put it on yours. If you have drum brakes or closed knuckle, then it won't be as easy. For the rear, If you have the 67-72, then a 1 ton rear from 73-up will bolt in. If you have 73 and up, then you need a 3/4 ton rear, NOT the 1 ton, the spring pad width is different. I have a Dana 60 front for sale, and can get a 14 bolt full floaters, so why not make a 1 ton?????
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 01-28-2005, 11:02 PM   #7
1FaastC10
1FaastC10's Avatar
brakes are not the same, the 3/4 tons use larger rotors.
Old 01-29-2005, 01:34 AM   #8
wanted
Also, if you have power brakes the booster is different. maybe the master as well. can't remember.
wanted is offline   Reply With Quote
Old 01-29-2005, 11:22 AM   #9
nu2-72
Call the Auto Zone at Belt and Messanie. There is a gal that works there. her husband works at Harley in KC. They have a 3/4 4x4 4 spd for sale. Sometimes the truck is there, sometimes at the house in Savannah.
This is the one that has the 71 cab on the 72 frame. Titled as a 71. 350 Goodwrench motor, 4 spd., 205, 8 lug, 33 x 10.5 x 16 tires and very nice wheels. Look like my Eagles. Bedsides are straight, tailgate nice, front panel and tubs are nice. The floor has some rust.
Front end fair. He has 2 extra doors and a fender that go with it.
Cab is air cab but air missing. Rockers have been replaced w/ corners. Fair job. Area above the windshield has been replaced inside. This is the biggest issue I had. They did not do a very good job here.
The truck is White, starts and drives well. No frills but a good starting point.
He told me $3000.00 3 weeks ago.
Wrecked the wifes car so may be willing to deal now..
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 01-29-2005, 12:41 PM   #10
Daubs
Daubs's Avatar
Thanks nu2-72! I will call.
Old 01-29-2005, 05:51 PM   #11
1FaastC10
1FaastC10's Avatar
this is true for 67-72 trucks, for 73-87 trucks, its the other way around. we dont know what year truck he is dealing with.
Old 01-29-2005, 10:04 PM   #12
nu2-72
We do know what he is dealing with. He does not own a truck yet but is WTB a 71/72 3/4 4x4 4 spd. Bottom of his sig and also in other posts.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 01-30-2005, 11:49 AM   #13
Slick71
Slick71's Avatar
Daubs...My truck was a 71 1/2 ton and I purchased a 72 3/4 ton for the axles. The axles were a direct swap and it was easy installing them. If I remember correctly, you've gotta buy new U Joints for the driveshaft, where it connects to the new 3/4 ton axles...if you plan to reuse your 1/2 ton driveshafts. The other guys are correct about changing spring perches on some of the 73 + year axles, but it's an easy modification! Good luck
BTW...don't know if your interested, but I've got mine for sale. Need around $6000. Email me if interested.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 01-30-2005, 03:21 PM   #14
1FaastC10
1FaastC10's Avatar
read further, it also mentions an 85-87. again, we DO NOT KNOW WHAT WE ARE DEALING WITH.
Old 01-30-2005, 10:02 PM   #15
Daubs
Daubs's Avatar
Thanks for the info guys.
I'm still looking for a truck, either 71-72 or 85-87 4x4.
Created this post to see what it would take to turn a K10 into a K20. Like the 8 lug 16" rims. Want to explore all my options now, before I purchase a truck.
Old 01-31-2005, 12:20 AM   #16
72k5
72k5's Avatar
I know for the 72, and I believe for the later model trucks, the front uses a larger rotor, but the calipers are the same. You can just use your calipers on the 3/4 ton rotors.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 01-31-2005, 04:38 PM   #17
Destructo
73-87 K20 and K10 share the exact same spring pad width and shock mounts, K30 trucks have a narrower pad spacing
3/4 ton rotors are larger and use the same caliper as K10 in 73-87 trucks, rear drums are also larger.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 01-31-2005, 04:40 PM   #18
nu2-72
http://67-72chevytrucks.com/vboard/s....php3?t=138549
MMMMMM!!
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 01-31-2005, 06:41 PM   #19
1FaastC10
1FaastC10's Avatar
let me also point out a little something else for you...
hopefully, nu2-72, you will understand this time. now :TFU:
Old 01-31-2005, 08:05 PM   #20
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
OK, you two play nice now
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 02-01-2005, 01:10 AM   #21
Destructo
the post nu2-72 said this in it
Wondering if anyone has taken the axles from an 80's 3/4 ton and put them under a 71-72 1/2 ton 4x4? Will the leaf springs bolt right on to the 71 mounts?
What issues did you run in to?
Thanks for the feedback guys. This board has been incredibly helpful to me. D.
In that post he is asking about putting a 73-87 14 bolt into a 71/72.
Old 02-01-2005, 05:16 PM   #22
nu2-72
My appologies to all. Daubs has PM'd me several times and posted several times regarding the placement of later axles into the 71-72 trucks. I thought that the question was pretty clear and the issue of purchasing a truck of a diferrent year was another thing altogether.
Daubs, if you would like to swing by sometime I have a 14FF on the stands with the perches and shock mounts already moved. A 10 bolt Corporate on the floor in the original position. A front Dana 44 3/4 on the stands going through a rebuild now and a Dana 44 1/2 ton in the shop as well. You can compare late model to early and 1/2 to 3/4.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
