PS pump and gearbox ?
I found a ps pump and gearbox, but , I don't know if they are from the same year model. From what year to what year will the pump and gearbox work together? I know somewear around 80' the fittings or threads went to metric. Any info. would be helpful.
Watch out for your cornhole !
![]() Join Date: Jun 2003
The secret is in the fitings on the lines. The early style is flare type and the later style is o-ring type.
You'll need a pump and brackets to fit whatever style of front engine brackets you're using, whether short or long water pump style. The 1 inch fitting screws out of the back of the pump so you can convert a pump to which ever one you need, flare or o-ring, just by swapping the fittings around.
Thanks for the help. I went and looked at them, he has the gearbox but not the pump. He has two gearboxes, one from and 81 and one form 82. I don't know if there is any difference in the two, I can get either for about $35. I'll probably take one and find a pump later.
Thanks again. |
