01-28-2005, 04:59 PM | #1 |
Strategery
Best way to move leaf spring perches?
Never done this before...do you reuse the old ones, or where do you get new ones?
01-28-2005, 06:13 PM | #2 |
Post Whore
If you have access to a plasma cutter you can probably salvage the old ones. If they are the cast type, probably can't cut them off clean enough to reuse.
If they are not cast, patience and a grinder will get the old ones off. I had to remove the spring perches on a 78 K20 axle to fit my 70 K5. I had a buddy remove the old with his plasma cutter when I finally gave up with my grinder. Had him also cut me some new spring perches - it's good to have a friend with a plasma cutter!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-28-2005, 07:00 PM | #3 |
Strategery
Can you buy new ones, or how do you make new ones? Unfortunately, i don't have access to a plasma cutter at the moment.
01-28-2005, 08:55 PM | #4 |
user # 2756
Here's a local guy to me that sells them $15 a pair. www.shakerbuilt.com
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-31-2005, 03:37 PM | #5 |
Get a cut-off wheel for your grinder and cut them out that way. Then switch to the grinding wheel and grind the rest of it off. A few wheels, a face shield, ear plugs and a whole lot of patience gets the job done. You can get new ones from the company JIMs70GMC suggested or I think even your local 4WheelParts has some. Have fun!
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
01-31-2005, 03:52 PM | #6 |
Strategery
I have the grinder and all the wheels I need. I'm probably going to buy a set from Tim at ShakerBuilt this evening. Thanks for the help guys. Oh, when I go to install the new perches, I know I need to set the pinion angle first. My truck is a stock '61 4x4 with no lift, short wide box with the t-221 divorced tcase. I never thought to check the angle of the original axle. I still have it, so would it be easiest to just roll that one back under, then set the new one and weld it up? Sorry for all the questions...just want to get this right the first time.
Thanks, Matt |
02-01-2005, 03:53 PM | #7 |
sound dumb but you can get them at a local chrysler jeep or dodge dealer in the mopar performance catalog i work at one and that is what i always use there pretty cheap too under $15 i think i can get a part number tomarrow if you want
02-01-2005, 04:10 PM | #8 |
chipolte... where are you located and do you have any pics of your 61..
my father has a 65 k10, 283 vette engine, SM420 and T-221.. 3.73 with posi rear, GREAT set up for towing.. he uses it weekly to tow 2.5tons of water..still starts off in 2nd gear...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 02-01-2005 at 04:12 PM. |
02-01-2005, 10:02 PM | #9 |
Strategery
I'm just east of Dallas. Currently the apache is a bare frame on jack stands. I'll have to get my pictures resized first so I can post them. But, I'm nearly ready to put the frame back together.
Matt |
